Anyone ever use an engine flush
Old Sep 13, 2011 | 07:58 AM
SJMaxSE's Avatar
My max has 140,000 miles on it,Thinking of using an engine flush on it,I work at a dealership and was going to use a BG kit,Just wanted everyone thoughts on the subject
Old Sep 13, 2011 | 08:05 AM
NmexMAX's Avatar
dot dot dot ...
I've done it before, but IMO, I think it's snake oil.
Or snake 710...
Old Sep 13, 2011 | 08:12 AM
SJMaxSE's Avatar
I know some guys swear buy it and some stay away from it,I flushed the motor today after just changing the oil on friday and it looked black as night,Put new oil in it and filter(Used Synthetic)Ill probally wait a week and repeat the process..
Old Sep 13, 2011 | 08:59 AM
nishfish871's Avatar
Are any of these products available at Autozone or Advance?
Old Sep 13, 2011 | 09:03 AM
NmexMAX's Avatar
dot dot dot ...
Yeah, there are a ton of varieties. I see no difference in my oil before or after when flushing or not.
So I decided I don't need or want it.
Old Sep 13, 2011 | 09:27 AM
ranmas2004's Avatar
I only think you need an engine flush if you don't change oil regularly. I can't see you really needing a flush if you stay up on regular oil changes.
Old Sep 13, 2011 | 09:59 AM
Flanker84's Avatar
I used the engine flush from Liqui Molly and I can say that it cleaned a lot of mud, gunk and debris in it without leakage problems.
Some people says that if you do a engine flush you remove "good" gunk in your engine that prevents leakage and even if this it's true then you probably got a lot of BAD gunk into your engine and more if you got a high mileage engine and don't do a regular maintenance schedule.
But if you want to use it it's your decision.
Old Sep 13, 2011 | 10:00 AM
NmexMAX's Avatar
dot dot dot ...
You have mud in your engine?
Old Sep 13, 2011 | 10:03 AM
ajm8127's Avatar
I was thinking the same thing. But back on topic, I agree with the post above that if you change your oil regularly, you should not need to flush your engine. Engine oil contains detergents that clean the internals with every change.
Old Sep 13, 2011 | 10:04 AM
Flanker84's Avatar
Some kind of mud that was formed by that damn Quaker State oil... You can see it and feel it just like mud. That was into the engine of my former car. Let me seek some pics of it to show you.
EDIT
A pic of the engine before the flush (Sentra 1.8 2001)
You can see the "mud" in the right side between sparks plugs 3 and 4
Old Sep 13, 2011 | 10:16 AM
ajm8127's Avatar
EDIT
Damn, that's absurd. What were your oil change intervals?
Old Sep 13, 2011 | 10:29 AM
Flanker84's Avatar
Every 5k Kms. At first I used Quaker State because a lot of people tell me that it was "the best oil" (yeah, sure...), but one day I changed the gasket of the valve cover and just freak out when I saw that "mud". The anger and frustration was huge, just imagine all that debris in the deepest parts of the engine almost make me cry.
I just made the engine flush and change to Castrol and no more "mud" from that day.
Old Sep 13, 2011 | 10:36 AM
SJMaxSE's Avatar
I wouldnt know about any after market oil engine flushes,I use BG from my dealer i work for,It spilled out some pretty nasty stuff today,I just bought the car so now im left with a gunky motor that someone didnt take care of,I guess thats the horror of buying a used car huh
Old Sep 13, 2011 | 10:38 AM
T_Behr904's Avatar
I don't know if I would use an engine flush or not. I would be nervous about any sludge buildup breaking off in a big chunk and it clogging something up. Then again after thinking about it for a minute, if I were to do a flush on my engine with 165,000 miles on it, I would want to remove the oil pan and give it a good scrubbing and to remove any chunks that would have broken loose.
Old Sep 13, 2011 | 10:41 AM
ajm8127's Avatar
BG makes good products. I used Auto RX on my car after I bought it before changing to synthetic. Auto RX is supposed to be more mild than most of the flushes to prevent large chunks of stuff from dislodging and getting caught somewhere important. Or at least that's what I have read.
Old Sep 13, 2011 | 11:08 AM
Rods03Max619's Avatar
EDIT
DAMN....
Old Sep 13, 2011 | 11:24 AM
With the way my car is burning oil, I thought it might be good idea. Because when my oil level goes down the oil gets dirty very fast. How about doing this and then seafoam thru the intake mani?
Old Sep 13, 2011 | 12:14 PM
SJMaxSE's Avatar
I personaly never used seafoam,Like many products you here good and bad
Old Sep 13, 2011 | 03:32 PM
marky3320's Avatar
I'm tempted to use AutoRX, but I'm afraid it might do more harm than good. The longest interval I had between oil changes was 4,500, but I try to keep it between 3-4k. Car has been running fine so far at 117k, except for that damn CES light.
Old Sep 13, 2011 | 03:49 PM
NmexMAX's Avatar
dot dot dot ...
I've gone in the neighborhood of 8-10k
Old Sep 13, 2011 | 04:06 PM
QT1 5MT AE's Avatar
Gram Lights addict
I bought my AE with 82k on the clock. I immediatly did one application of auto rx (sludge remover) and switched over to synthetic. have about 96k on it and car runs like a champ. I have done full maint. and get upward of 30mpg highway too.
Old Sep 13, 2011 | 05:25 PM
SJMaxSE's Avatar
I as well am going to use synthetic oil from this point on,Ill do another flush in a week and i should be good
Old Sep 13, 2011 | 05:31 PM
marky3320's Avatar
I switched to synthetic a few months back recently without doing Auto RX...should I go and flush with Auto RX on my next oil change?
Old Sep 13, 2011 | 08:41 PM
ranmas2004's Avatar
EDIT
W T F!!!! Are you the original owner? Maybe someone had it before you and did not regularly keep up with oil changes.
Old Sep 13, 2011 | 09:03 PM
Any after pics??
Old Sep 13, 2011 | 09:20 PM
QT1 5MT AE's Avatar
Gram Lights addict
how many miles on your car? are you the first owner? has the car had proper oil change intervals?
look on auto-rx's website to answer all your questions. for $27, it doesnt hurt. and it helps switch to synthetic the proper way for higher mileage cars.
Old Sep 14, 2011 | 07:12 AM
Flanker84's Avatar
I was the second owner. The first owner... was a girl.
Any after pics??
Sorry, I can't find that pictures but I know that I take photos after the engine flush and let me tell you that all it almost shined like new after that.
sctludwig
Sep 1, 2022 01:32 PM
RWCreative
Sep 21, 2015 11:01 AM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
Violator
Sep 9, 2015 10:14 AM
