2002 6mt shift knob problems with reverse !
Old Sep 18, 2011 | 12:17 PM
NiSmO5ThGeN's Avatar
2002 6mt shift **** problems with reverse !
i ordered a nismo shift **** its a white **** with a lip kinda looks like a lollipop and it says nismo on the lip. but with the **** installed the reverse doesnt work and i paid 95$ for the **** im not going to just take it as a loss, what can i do other than unscrewing it everytime i need reverse.
Old Sep 18, 2011 | 05:28 PM
LongoTE's Avatar
Do you mean it screws down too far and you cant pull the ring up for reverse? Maybe a dab of glue and a little metal washer on top of the metal stick so the **** will still screw down tight, but not go down as far.
Old Sep 18, 2011 | 05:38 PM
Rochester's Avatar
This one here? The one that has the following disclaimer...?
NOTE: Does not fit Altima or Sentras SE-R/SPEC-V equipped with the Reverse Lockout Mechanism?
Yeah, that's a shame. Maybe it's another ****, because this one is only around $70, not $95... although it certainly looks like a lollipop, and says NISMO around the lip. Lollipop? LOL
I think yours is the first sig I've ever seen that itemizes factory standard features on the SE model. Feeling the pride, man.
Old Sep 18, 2011 | 06:28 PM
Xpcgamer's Avatar
You needed one of these. I may be ordering one of these as the OEM one is around 80 bucks I think.
http://www.twmshiftknobs.com/shiftkn...hiftknobs.html
You would have to have the bottom of that **** drilled out at least 1" at the bottom and at least 3/4" deep to allow the lockout to move up. Since you have the **** already I would try and do that. Make sure not to screw up the threads of course
Old Sep 19, 2011 | 01:36 AM
knight_yyz's Avatar
Toolie
you can use a drill and drill a small hole in the reverse lockout mechanism, tap out the dowel, then remove the lockout mechanism
Old Sep 19, 2011 | 06:37 AM
zero2sixtyZ's Avatar
You embarrass me.
Old Sep 19, 2011 | 04:49 PM
Eirik's Avatar
How complex is the lockout stuff? Mine is el non-function-ito and I'm tired of shooting off into space instead of hitting 5th. I'm sort of dreading the repair, as Rochester's writeup on installing the shifter bushings seemed like there's lots of patience needed when working with all those washers and cables. My 350z owning cousin says there's a plate that serves the lockout functionality, and he installed his backwards after some mod he did and 5th and 6th were messed up (unable to be shifted into or something) until he realized what he did. He wasn't sure how the FWD 6-speeds do it, though.
Old Sep 19, 2011 | 05:12 PM
knight_yyz's Avatar
Toolie
The lockout is just a plastic shaft that moves another smaller piece of white plastic. The white plastic prevents the shifter from moving to the R position unless of course you pull up on the lockout. then the smaller white piece is not blocking the movement.
Old Sep 19, 2011 | 05:47 PM
Rochester's Avatar
But it's also one of those things that seems stupidly easy after you actually do it. Hindsight rocks.
Old Sep 19, 2011 | 06:01 PM
TunerMaxima3000's Avatar
I wouldn't have noticed that, thank you, I had a good
Old Sep 19, 2011 | 06:44 PM
Eirik's Avatar
Drat. That means my problem is a compound one. =/
1. Lockout doesn't work.
2. Shifter "gate" is messed up, allowing shifter to move to empty space paralleling 5th gear.
I'm crossing my fingers that something obvious got missed when they replaced the transmission in this car ~40K miles ago.
Old Sep 20, 2011 | 07:40 AM
jay d emm's Avatar
sounds to me like you'll be needing some parts... good thing my car was totaled and pretty much everything is working properly (except the rear end)
Old Jun 14, 2013 | 02:29 PM
Bro I have it in my 2002 6mt maxima and it does not do reverse I unscrew it daily
Old Jun 14, 2013 | 03:27 PM
steezmuffin686's Avatar
the price to pay for steez op. LL
Mar 12, 2020 12:06 AM
dcam0326
Sep 18, 2015 04:52 PM
Colossus
Sep 9, 2015 05:46 AM
GregL65
Sep 7, 2015 10:33 PM
Justin Kroll
Sep 2, 2015 11:06 AM
