02 - Fresh Motor...Codes!
Old Sep 18, 2011 | 05:42 PM
nismomaxx's Avatar
As the title states, I got a 2002 with a Fresh(er) motor...32k on the new one. Got a code that I can't shake...seems to be a tough one!
P0335 - Crankshaft Position Sensor Bank A - Malfunction
I replaced it today with one from Autozone with NO change at all. Rough start, misfiring and such....anyone?
Old Sep 18, 2011 | 06:40 PM
maxima dude's Avatar
never use a autozone pepboys etc sensor...nissan sensors are very sensitive and u shuld only use oem sensors...return that sensor and get a nissan sensor...
Old Sep 18, 2011 | 06:53 PM
nismomaxx's Avatar
and this will fix it all? really? someone said to me that there was a recall or TSB for these..anyway to find out right this second if mines covered?
Old Sep 18, 2011 | 09:08 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Go to the dealer and have them run your VIN to see if all TSBs/recalls have been fixed.
+1 on OEM crank sensors. I've seen a few threads where the autozone sensors just didn't work at all. Also, clean the connector thoroughly (as per another thread).
Old Sep 18, 2011 | 09:29 PM
NotoriousMaxx98's Avatar
im had the same problem with my VQ30de Nissan sensor all the way. I learned my lesson with autozone advanced auto and pepboys.
Old Sep 19, 2011 | 09:57 PM
Amave's Avatar
op did you install the flywheel or flexplate correctly to where the sensor reads the tone ring correctly?
IIRC the FW/FP only goes on one way, iut has a dowel . Check grounds on that circuit.
if it checks out try the FSM procedure.
Did you have any problems before the install?
Old Sep 19, 2011 | 11:48 PM
tedo007's Avatar
faster than you think
My car threw the same code and I changed the sensor and didn't do anything. Then I checked the coil pack and it was bad. Got my problem solved.
Old Sep 20, 2011 | 05:11 AM
MrEous's Avatar
^ Jeff™
Dealer will run his VIN...his VIN is associated with the old engine.
tsi6001
Oct 3, 2022 10:23 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
zmcneely13
Sep 26, 2015 02:26 PM
cruce91
Sep 20, 2015 10:23 AM
Pixel
Sep 15, 2015 05:53 AM
