P0455, where to look for leaks
Old Sep 19, 2011 | 04:54 AM
Calcvictim's Avatar
I got the code, bought a new gas cap and the code came back. Before I order new parts I want to check if maybe the tubing is cracked around the canister or valve. Where is the location of the evaporator canister and valve?
Old Sep 19, 2011 | 07:19 AM
gjaa's Avatar
The canister is behind the rear driver side tire. What valve are you talking about? There are quite a few in our cars!
Old Sep 19, 2011 | 08:28 AM
Calcvictim's Avatar
I am talking about the vent control valve, is that not obvious from my question in regards to the location of the evaporator canister?
I got the P0455 code, and from all the threads I see people get two codes, the second being P1148. Before I order any new parts I want to check I don't have a ripped hose, hence me asking for the location.
Old Sep 19, 2011 | 09:02 AM
gjaa's Avatar
Isn't that right infront of the canister? Looking at the canister from the front of the car the vent control valve is the one on the left side of the charcoal canister
And there is another few valves that are partbof the evap system, there is the one that the smoke machine goes into to check for leaks and there is the valve that goes into the canister from the engine
Old Sep 19, 2011 | 09:33 AM
three.fiveSE's Avatar
The canister/valve are under the car, driver side rear, next to the gas tank as gjaa mentioned.
Coincidentally, I logged on to look into this as well. Does any know if the canister from an 04 max is the same as the 03?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
followthadollar
Sep 17, 2015 06:31 PM
