WHere to find a used 2k 5-speed tranny?
Old Sep 19, 2011 | 06:24 PM
Whitemax's Avatar
Disco Biscuit
Mines definitely on its way out. So I need to start looking. Ive hit the fs section here, as well as car-part.com, but I cant bring myself to pay $800 or more for a 150k + transmission. I'll be replacing the clutch and maybe flywheel too it it needs to be, so I need to try and keep the cost of the tranny down, since its going to have to be shipped adding a couple hundred more to the cost. I know I'm not the first guy to have to deal with this!
Old Sep 19, 2011 | 06:31 PM
BigLou55's Avatar
your local junkyard is the best location to look for a low mileage tranny if your trying to keep the cost down, not sure of cost but shouldnt be too much good luck
Old Sep 19, 2011 | 06:41 PM
Whitemax's Avatar
Disco Biscuit
Thats the issue Im having. I live in a pretty rural area in Central IL, and so far I havent been able to locate a 5 speed. The autos are a dime a dozen, but speeds are non existent ....
Old Sep 19, 2011 | 06:42 PM
T_Behr904's Avatar
I believe the same 5 speed was used in 4th gens as well. I would call some reputable transmission shops around your area to see how much it would cost to have yours overhauled if you can't find a replacement.
Old Sep 19, 2011 | 07:13 PM
Rods03Max619's Avatar
Yeah, odd area, out here the tranny can go for like 600 or less with 60k or less on them.....you should check a little further out maybe a place can ship it to you for not that much money...Good Luck...
Old Sep 19, 2011 | 07:49 PM
Whitemax's Avatar
Disco Biscuit
I think it is the same, but I'm still trying to find out for sure, since they can be had for a bit less. If anyone has some input, feel free to chime in.....
Old Sep 19, 2011 | 09:28 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
www.car-parts.com or do a search for brandywine automotive here in md. get you set up.
Old Sep 19, 2011 | 09:48 PM
Amave's Avatar
op what is your 5 speed doing that you need a new trans?
lately mine has been clunking when i let out ,y clutch but only in 3 and 4.
it almost sounds like an inner cv joint clunking
Old Oct 3, 2011 | 03:00 PM
Whitemax's Avatar
Disco Biscuit
Input bearing noise, trans fluid leak, and now has stopped letting me shift into first or second
Old Oct 3, 2011 | 07:25 PM
036mtmax's Avatar
There's one in mass,01 LSD 5mt..henry's used auto parts
Old Oct 6, 2011 | 09:43 AM
jtm02011's Avatar
How much they looking for the LSD^^?
+1 to car-part.com....found on on there and had it shipped to my dads shop in CT from PA and it was 550 with 100K on it...also had the same exact symptoms you had, except mine locked up in second gear, though first and second were getting hard to shift into.
Old Oct 6, 2011 | 10:01 AM
aackshun's Avatar
Sounds like someone should do a 6MT swap...
Old Oct 6, 2011 | 10:12 AM
L36's Avatar
L36
This if rebuild costs a fortune or cant find a replacement.
Old Oct 6, 2011 | 11:12 AM
aackshun's Avatar
It'll be cheaper and more beneficial to do a 6mt, just sayin'.
Only way I can forsee a 5MT > 6MT is if you're under a time crunch and can't spend the time it takes collecting parts and day or two of fab work....
pktaske
May 6, 2016 07:49 AM
Vistance
Sep 17, 2015 05:17 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
