Replacing exhaust manifold gaskets
Old Sep 20, 2011 | 01:52 PM
pkrainert's Avatar
Hey Guys,
The wifes 01 sound like crap, it sounds like its leaking by the exhaust manifold in back, I am not 100 percent sure but I wanted to ask how hard they are to replace? I also wanted to take the front manifold off anyways to replace that coolant plug since it was leaking before. I tightened it but I would like to use a sealer or buy a new plug for it.
I am going to take a closer look when I get some time before I start taking stuff apart, I also suspect it could be the EGR valve since I am throwing an EGR Code. Does anyone have a detailed picture of where the EGR is located?
Old Sep 20, 2011 | 01:59 PM
NmexMAX's Avatar
dot dot dot ...
It's like a header job, so, yeah, not fun removing the pre-cats at all, especially on a 10 year old car.
Old Sep 20, 2011 | 02:15 PM
pkrainert's Avatar
I hope it is the EGR........ lol I am so tired of working on this car.
Old Sep 20, 2011 | 02:27 PM
Flanker84's Avatar
Maxima 2000-2001 3.0 doesn't have EGR.
Old Sep 20, 2011 | 02:30 PM
pkrainert's Avatar
OK well what is my p0400 code for then? My scan tool says low EGR flow?
Old Sep 20, 2011 | 02:32 PM
NmexMAX's Avatar
dot dot dot ...
Yes they do. 02-03's do not, or rather it's internal vs external.
Old Sep 20, 2011 | 02:39 PM
Flanker84's Avatar
Well, I searched in the FSM and it doesn't show an EGR. I know that some cars got it but I don't see it in my car or in the FSM. I only can see a pipe that looks as the EGR but it's somekind of support for the TB.
Old Sep 20, 2011 | 03:14 PM
pkrainert's Avatar
Is the FSM online? I used to have a link but I cant find it. Maybe its not called an EGR and that is why it't not listed? I just want to fix my car man.
Old Sep 20, 2011 | 03:32 PM
NmexMAX's Avatar
dot dot dot ...
Choose your year:
http://www.nicoclub.com/FSM/maxima/
Old Sep 20, 2011 | 03:48 PM
pkrainert's Avatar
You are awesome, thank you!
Is there any type of write up for the 2000-2001? I found a great one in the 4th gen forum a while back but I cant find anything on the 2000-2001.
Old Sep 20, 2011 | 04:59 PM
Clashez's Avatar
why stop at just repacing gaskets, when u can replace the exhaust manifold to with headers for added power.......
Old Sep 20, 2011 | 06:17 PM
spock's Avatar
....and a loop de loop muffler... merrel bent, of course.
Old Sep 20, 2011 | 06:26 PM
McSteve's Avatar
aaactually i think only 2000 have external and 01+ have internal. at least i didn't have any egr equipment on mine
Old Sep 21, 2011 | 06:45 AM
NmexMAX's Avatar
dot dot dot ...
Makes sense, sorta... But it still needs to be there. The 02-03 do it via CVTC, how does the 01 do eet?
Old Sep 21, 2011 | 10:03 AM
pkrainert's Avatar
I actually have a 2000 I don't know why I said 2001. I will check it out when I have some spare time and if I find anything interested I will let you know.
I am not interested in doing anything to make this car faster lol.
Old Sep 25, 2011 | 05:17 PM
Flanker84's Avatar
I don't know but I found something interesting in our VQ30DE-K yesterday when I changed the gaskets in the valve covers and intake manifold.
Intake manifold in place
Intake manifold removed
Check the place where the TB it's placed (near of the rear Valve cover). Did you notice a small amount of oil over the metal plate with the shape of a triangle? Well, in the intake manifold just after the TB we have a hole... Yes, a damn hole with a gasket that leads to that metal plate! Why it's that hole there? I don't know but it's interesting. Maybe it was designed to be connected to something but Nissan's engineers doesn't put it.
Old Sep 25, 2011 | 05:40 PM
CMax03's Avatar
yes they do!!!!!!!!!!!!!!!!!!!!!!!!!! Located just behind the TB!
Old Sep 25, 2011 | 05:46 PM
CMax03's Avatar
The exhaust gasket are Stainless Steel and are bulletproof....and don't just start leaking more than likely it's your EGR gasket since they are part of the UIM and held together with 2 long bolts...
Old Sep 25, 2011 | 05:56 PM
Flanker84's Avatar
GOTCHA!
http://forums.maxima.org/5th-generat...nets-01-a.html
The same factory plate in my Max.
vingodine
45
May 21, 2016 12:46 PM
ac max 92
Sep 2, 2015 04:23 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
george__
Aug 18, 2015 07:06 PM
