P420, P430, and P1320
Old Sep 29, 2011 | 07:15 AM
Hoffm2ma's Avatar
Okay, sorry for the long post but this is driving me crazy. I have had my SES light on and off now for about 6 to 7 months. First I was getting the P420 and P430 code, but now I am getting those plus P1320. I keep resetting my ECU but they keep coming back and now my car is starting to hesitate but no SES flashing.
I checked all the coils and they are fine, the MAF sensor was replaced about 30k ago, and my plugs have about 15k on them.
Here is my plan for Columbus Day weekend, I am going to gut the pre cats, clean the MAF, change the fuel filter, change the plugs, and any other suggestions you guys might have.
I am going to use the non-foulers for the O2 sensors, but if I pull the main cat off and it is all clogged, can I gut it or should I get a test pipe (live in VA so need to take off for inspection), Also would I need a non-fouler for the O2 after the main cat?
Old Sep 29, 2011 | 07:19 AM
clintb3astwood's Avatar
The p1320 could be due to poor voltage. Have you used a voltage tester? And the other codes are definitely cat related. You could do a high flow cat or a test pipe. Me personally i care too much for the enviornment lmao
Old Sep 29, 2011 | 08:12 AM
Hoffm2ma's Avatar
No, where would I test the voltage? I did read that the p1320 code could also be one of the plugs on the coils.
Old Sep 29, 2011 | 11:17 AM
T_Behr904's Avatar
I've had the 1320 code now for a long time. I've even heard that the crank sensors can cause it.
Old Oct 1, 2011 | 08:45 PM
Hoffm2ma's Avatar
Yeah, I just ordered the test pipe from an fellow org member. Do I have to use an non-fouler after the test pipe?
Old Oct 1, 2011 | 10:49 PM
OnOiShNo0dl3Z's Avatar
No, there are no O2 sensors after the main cat/test pipe. You will need the non-foulers on the pair of downstream O2's which on the 5.5 gen are both on the y-pipe and I'm assuming the same goes for the 5th gen.
Old Oct 2, 2011 | 08:34 AM
Hoffm2ma's Avatar
Thanks man.
Old Oct 4, 2011 | 03:19 AM
Hoffm2ma's Avatar
So on the way home today I got the flashing SES light, pulled the code and it was P0305, which is a cylinder #5 misfire. Could this have caused the P1320 code as well?
Old Oct 4, 2011 | 07:27 AM
sontakke's Avatar
Yes indeed; in most cases usually you only get P1320. Since you have the P0305, you are lucky. Hopefully, it is simple like coil or spark plug for that cylinder.
Old Oct 4, 2011 | 08:59 AM
Hoffm2ma's Avatar
Thanks man, this is the same coil I had go bad last year, and I got a new one at Autozone. Hopefully it is still under warrenty.
Old Oct 5, 2011 | 06:40 AM
sontakke's Avatar
If you can get OEM coil either via a dealer or mail-order or ebay, you would not have to go through this again.
Old Oct 5, 2011 | 10:09 AM
Hoffm2ma's Avatar
Okay so after some research, I found this:
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
http://nissanhelp.com/diy/maxima/pro...tification.htm
They both say I do have a O2 sensor after the main cat. Do I need a non-fouler for that O2?
Old Oct 6, 2011 | 06:40 AM
sontakke's Avatar
That chances of your Maxima being Fed spec are very very low. It is most likely going to be Cali spec.
Old Oct 7, 2011 | 05:10 PM
Hoffm2ma's Avatar
Thanks man, you were right started working on this today. All the bolts on my main cat are rusted to ****. I have heated them up, loaded them with PB blaster, and still can't get them to move. Any suggestions?
Old Oct 11, 2011 | 09:11 AM
Hoffm2ma's Avatar
So I changed my plugs, fuel filter, coil, oil, and cleaned my MAF. When I changed my plugs I noticed alot of oil in the cylinder with the bad coil, this is the second time this has happened. Could this be from the bad coil, or from the spark plug gromments? Should I replace the gromments and the VC gasket? I have read about the 5.5 gen problem and having to replace the VC. Please Help!!!!
Old Nov 8, 2011 | 10:15 AM
Hoffm2ma's Avatar
So I got everything back together, replaced seals, coil, gaskets, and did the VIAS fix. Now I still have a p1130 code, Swirl Valve? Please Help!!!!
Old Nov 8, 2011 | 04:05 PM
BigLou55's Avatar
did you put all the piping to the vias back correctly? I know if you have a cali spec there are 3 hoses that go into the vias assembly, federal spec just has 2, just a thought.
Old Nov 8, 2011 | 04:58 PM
Hoffm2ma's Avatar
Thanks for the help man, Yeah I got three connected. I will try to post pics maybe I have hose hooked up wrong. I have no idea whats wrong, car runs fine, no noticable difference. Is there a fuse for the sensor? I haven't check that yet.
msellas
Sep 23, 2015 09:16 PM
sake1bs
Sep 19, 2015 09:32 PM
2kBlkMax
Jan 16, 2005 08:17 AM
panda_1
Mar 27, 2004 12:59 PM
