EXHAUST SYSTEM
Old Oct 5, 2011 | 10:06 AM
HOMERUN4THGLE's Avatar
EXHAUST SYSTEM
Alright guys and gals I need advice as to what to install on my 2000 Maxima. My exhaust system is on its kast leg and I can tell it is affecting my engines performance. I am not big on mods on a car but my friends have advised me to buy an aftermarket exhaust system. I have been told they are better and helps the car perform better and i am all for that! So I need suggestions and advice from those who have done this. Thanks in advance!
Old Oct 5, 2011 | 10:08 AM
phatboislim's Avatar
you want noise?
Old Oct 5, 2011 | 10:14 AM
Do you have an idea of what's bad?
Old Oct 5, 2011 | 10:15 AM
The6spdMax's Avatar
Cattman, frankencar (if you are lucky), megan...
Old Oct 5, 2011 | 10:18 AM
Don't forget eBay!
Old Oct 5, 2011 | 10:23 AM
The6spdMax's Avatar
Don't forget eBay!
Unless he wants a fart-can.
Old Oct 5, 2011 | 10:26 AM
if he doesnt want noise, he might as well go back to the stock route, period
Well eBay offers two styles. One like the Greddy EvoII, one like the Megan.
T_Behr904's Avatar
BRM
Old Oct 5, 2011 | 10:27 AM
TunerMaxima3000's Avatar
Search for the Twin Loop thread, it will provide all the answers you desire.
Old Oct 5, 2011 | 10:28 AM
Thought Greddy EVO2 was long discontinued
Old Oct 5, 2011 | 10:32 AM
ranmas2004's Avatar
If you not big on mods then perhaps you should just go back with stock. If you want a little more performance you can get an aftermarket 2.5" exhaust and KEEP the stock muffler...that way you will have no noise. Honestly, though, if you have NO other mods on your car and don't plan on modding it then I would just go back to stock exhaust system. Modding only Catback will give minimal gains.......probably won't even feel it.
Old Oct 5, 2011 | 10:49 AM
It's a knockoff of the actual Greddy. I'm sure you've seen them all over the place on eBay.
Old Oct 5, 2011 | 10:53 AM
Rochester's Avatar
Lucky? Quiet and pretty, but little performance.
Besides, the OP probably has no access to a Time Machine.
Old Oct 5, 2011 | 10:55 AM
I am not big on noise but I am not against an agressive sounding exhaust that will not wake up the neighborhood.
Old Oct 5, 2011 | 11:05 AM
i have a custom catback on mine
warpspeed ypipe 22" magnaflow resonator 2.5" piping to a cattman axleback...other than the hole in my ypipe from riding too low, sounds excellent...crazy but i've gotten more compliments on my exhaust w/ the hole in teh ypipe
its tone, not obnoxiously loud, i love it, personally.
Old Oct 5, 2011 | 11:06 AM
McSteve's Avatar
open headers FTW
Old Oct 5, 2011 | 11:08 AM
Rods03Max619's Avatar
Knockoff style not a real Greedy....
Old Oct 5, 2011 | 12:01 PM
Elaborate
OK here is my thoughts on mods....Mods may cause more problems down the line.
Is this Fact or Fiction?
What mods can be performed without breaking the bank and making a aftermarket performance exhaust purchase and install worthwhile?
Old Oct 5, 2011 | 12:05 PM
the exhaust wont, you arent doing anything towards the engine, you'll be fine in that aspect
Old Oct 5, 2011 | 12:13 PM
03VQMAX's Avatar
BRM
+1, that will be my next exhaust
Old Oct 5, 2011 | 12:32 PM
Rochester's Avatar
Fiction.
Ignorance, poor-quality parts, and cutting-corners are what can cause problems down the line. Mods done correctly and responsibly with quality parts only enhance your experience with the car...
...unless the results aren't satisfying, in which case you're screwed.
Old Oct 5, 2011 | 02:24 PM
Thanks for clearing that up boys
"Where we're going, we don't need roads" Duh duh da na na....
Old Oct 5, 2011 | 02:37 PM
maxurlife's Avatar
Seems like, from what I've been reading, for the 3L 5th gen a 2.5" cat back is the best. I think I saw that cattman is offering another build, specifically of 3" but I'm sure you can get a 2.5 in the loop. If you're not going heavy on mods but you're going to upgrade the exhaust, then you may as well at least get an air filter as well, they are inexpensive and a great compliment.
Personally I have purchased an ebay exhaust but sold it NIB for the 3" cattman with a resonator on my 3.5L It's quite at idle and cruising, aggressive sound under load. The ebay unit, once installed was incredibly loud and the owner used the piping with the factory muffler to quite it down. He had a set of OBX headers installed at the time which also added to the sound. But he said it was a horrible note and drone.
If you go to the local shops, then try your best to find a shop that is mandrel bend capable, that will give you the true exhaust flow that you pay for. But I'm sure there are plenty of posts where orgers have had great experience with the systems they have purchased local/custom I'm sure not all were mandrel bent.
Good Luck - Why be you, when you can be NEW!!! (Robots, what a great film) UPGRADES ROCK
Old Oct 5, 2011 | 02:50 PM
aznaliaz's Avatar
2.5" for cattman is better with the 5th gens most gains. 3" better for 5.5 gens
Old Oct 6, 2011 | 08:49 AM
jtm02011's Avatar
Just get a megan, pretty inexpensive, and not loud at all until you start adding other mods (y-pipe, headers, etc)
And the comment about 3.0's not benefiting from a 3" exhaust is subjective. It's going to depend on having the supporting mods for the 3.0, stock for stock, there are minimal gains if any and the 3.5 benefits greatly, but with I/H/HFC, spacers etc...
Old Oct 6, 2011 | 08:57 AM
NmexMAX's Avatar
dot dot dot ...
I'll add my 2 cents:
1.) There re no definitive results or dynos for the DEK + 3" anything, Cattman or otherwise.
2.) Aftermarket systems are typically far cheaper than OEM, from the factory of course.
3.) No cat-back by itself will make much noise if any at all, since he doesn't even have a y-pipe. All of us should know by now that, stock headers, y-pipe, and cat will quiet anything down, no matter what. I had a straight through tiny muffler, 2.5" catback with no resonator, and it was hardly, i mean HARDLY noticeable on my 4th gen. Save the comments for ZOMG!!111 it's a 4th gen, apples to oranges. I've worked on plenty of 5.0 gens to say, no, in the exhaust department, they're nearly identical.
4.) What were we discussing again?
5.) Oh yeah, OP, if anything, go to your local shop and have them fab you one. I paid 225 for a catback + muffler. Was it mandrel bent, no, is it stainless, no, did I care, no. Should you, probably not.
6.) If you plan on modding, you need to hang out on here and read the many threads on it, it's not for the faint of heart.
To sum it up ....
Old Oct 6, 2011 | 09:12 AM
nishfish871's Avatar
+2, but it will not sound stock. Glad to see someone bring them up...i feel like the only one who has it.
Old Oct 6, 2011 | 09:58 AM
TallTom's Avatar
Do you have the BRM 2.5 or 3"?
Old Oct 6, 2011 | 10:32 AM
NmexMAX's Avatar
dot dot dot ...
3"
Old Oct 6, 2011 | 04:21 PM
BobPezz's Avatar
This is like deja vu! Here we go again. There's a similar discussion in this thread. http://forums.maxima.org/5th-generat...ease-step.html Check it out for more info. to help with your decision/confusion.
Old Oct 6, 2011 | 10:04 PM
UNDER ADVISEMENT
THe only thing I have on my car is a K&N filter and it is not a CAI. I appreciate all the advice. I am going to check out some local shops. and check some of the threads suggested. Thanks for all the tips.
Old Oct 6, 2011 | 11:23 PM
KnightRyder8776's Avatar
I have a 2.5" single tip OBX catback with a megan test pipe on my 02. Stock y pipe and precats still in place (for now until the OBX headers are available again) and right now I love the tone. Nice and agressive paired with my berk intake
Old Oct 7, 2011 | 04:30 AM
BobPezz's Avatar
Not always true. http://forums.maxima.org/5th-generat...ml#post8249660 Caveat Emptor!
Old Oct 8, 2011 | 04:54 PM
maximalxl's Avatar
here is how my car sounds....i went to my friends muffler shop and installed SpeedRex (it was done about 4 yrs ago and love it)
http://www.youtube.com/watch?v=kZ06-9YKEHM
Old Oct 8, 2011 | 04:55 PM
maximalxl's Avatar
here's my car with flowmaster 600 series
http://www.youtube.com/watch?v=rceE76b26T8
i didn't like coz it was too loud for me...
Old Oct 8, 2011 | 06:02 PM
barkins's Avatar
I'd avoid anything that makes excessive noise just for the sake of making noise.
Unless it adds something substantial to car's performance, I wouldn't bother with a noisy exhaust. Just my two cents.
Old Oct 8, 2011 | 10:19 PM
kbcnd's Avatar
Not trying to thread jack here, my question goes along with the OP's.
I'm in the market for a new exhaust set; there is current 133xxx miles on the OEM one and I think it's time for a change. I planned on keeping stock headers, but if I need to/should change them, I will, budget permitting. I want something that has a nice deep tone to it at idle but it not overwhelming when cruising. I've done searching and looking around and I can't seem to find everything that I need in one place.
Basically, what I am in need of, is exactly what parts would I need to buy and from what manufacturer in order to accomplish my goal. Any and all help would be greatly appreciated. Thanks
Old Oct 9, 2011 | 02:08 AM
evoTimer's Avatar
this may help: Mandrel Exhaust Systems <click there
Flowmaster and Flowtech make beautiful sound, but they will destroy your performance since they have more backup pressure than OEM mufflers
Old Oct 9, 2011 | 02:49 AM
CATTMAN=FTW in that case....good with just the exhaust when the Headers arrive and I install I will elaborate on the sound.....
