Key FOB programming
Old Nov 3, 2011 | 04:57 AM
oxygen's Avatar
Key FOB programming
Hi, I have a 2000 Maxima and I'm trying to program a new key fob to replace mine with a broken lock button. To the best of my knowledge I must insert key in ignition 8 times in 10 seconds w/ doors locked from inside, then look for hazzards to flash, put key in ACC position and then press a button on the remote. However, when I am inserting the key 8x in 10 seconds I cannot get hazzards to flash. Is my programming procedure incorrect? What can I do at this point to troubleshoot, or will my car never have a working FOB again?
Thank you!
Old Nov 3, 2011 | 06:49 AM
VQP0WER's Avatar
You are probably going to fast removing the key. It only needs to be 6+ times in 10 seconds, withdrawing the key completely between insertions.
http://www.courtesyparts.com/instruct/remote.html
Old Nov 3, 2011 | 06:52 AM
essential1's Avatar
My axles cry for mercy...
Yup. Most likely you're going to fast. It usually works after the 6th time for me. Try 6 times in 10 seconds instead.
Old Nov 3, 2011 | 09:54 AM
oxygen's Avatar
ok thanks let me give it a shot slower when i get home
thanks!
Old Nov 5, 2011 | 09:14 AM
oxygen's Avatar
Tried doing it much slower this time but to no avail, still can't get hazzards to flash. Anything else I can do besides bring car to dealer?
Old Nov 5, 2011 | 10:25 AM
cabernet's Avatar
I had the same problem. Never got the hazard lights to flash so I went ahead with the rest of the instructions and it worked anyways.
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
QueensMAX
Sep 15, 2015 04:14 AM
