Is my clutch master cylinder bad?
I installed a new slave cylinder and I'm trying to bleed it. I topped the MC off with brake fluid and saw that the old fluid was rather cloudy. I thought it was odd, because my tech said he replaced the fluid a year ago. Steadfast, I pushed onward.
My father and I tried the pump method for about 10 minutes but, not a single drop of fluid came out of the bleed screw on the slave. Appropriately, the fluid level in the MC reservoir did not change whatsoever. Finally, I attached my power bleeder and applied 4 psi to the MC. There is no fluid movement, as if there was a blockage somewhere in the hydraulic system. I tried pumping the clutch and, it made no difference. While there is no pressure in the clutch, it does return to the top, even when the lower bleed screw is open.
I'm thinking the MC is bad, no? Should I waste more time trying to bleed this or, just have it towed to the dealership for MC replacement?
Thanks.
Thanks.
I had the hose going to the master cylinder replaced in my car by a friend who is a mechanic, at the dealer I used to work at. They are a biotch to bleed. It took him and another tech, and a power bleeder to do the job, and they bled it for probably 2 hours or more. Air travels upward, so try the upper bleeder first before you take your car to the stealership and spend money on a tow.
Fluid has to be able to move from the MC to the slave for the clutch to work. If pressure is applied to the reservoir fluid but, nothing flows to the slave, something's fishy. Air won't stop the flow of fluid in an open hydraulic system. It will just compress until pressure is equalized. Fluid should still flow without obstruction. I think there is something stuck in my MC or, perhaps, it's just beyond it's years.
I've got AAA so, the tow will be free. I need some other work done to the car, work that I either cannot or will not do myself so, this isn't so bad.
t6378tp
Sep 29, 2018 04:27 PM
bbsitum
Sep 11, 2015 04:55 PM
