only drop front???
only drop front???
whats going on guys i have some springs layen around...i just installed my struts as they where done..how would just droping the front on h techs look? on my 03 maxima..i have h tech fronts layen around as well as h&r rears
It wouldn't handle very good with that combination. If you have 4 why only do 2? Think about when you corner. your fronts would be stiff and the rears wouldn't. It would almost sit back making a sharp right and then your front left wouldn't have the weight on it that it should. Replacing only 2 is never a good idea, unless of course you only have time to do 2 and will do the other 2 shortly there after
Housecor ran Progress springs in the front of his car, and stock springs in the back on Illuminas with no issue.
If you're just looking to balance out that atrocious front wheel gap with the rear, lowering just the front isn't going to hurt the car. It's not like he's doing it to go racing with, guys.
I've always lived by "do it right the first time, or don't do it at all" so as I've said already, I'd save up the money and get coilovers.
If you just want to level the front out I don't see any reason not to just drop the front. However I don't understand why you would do the struts and put the stock springs back in then choose to change out the springs.
Considering the pics on housecor's thread don't work anymore, here's a pic off of his website:
That's stock rear and H&R fronts.
More pics are here:
http://shiftice.com/2004_11_09.html
More pics are here:
When replaced my struts/springs with Eibachs + Gr2s, I did the front first, then did the rear a week later. I remember the handling being much more crisp and felt safer in the curves with the front only compared to all stock. Also I kind of liked the look. The rear fender gap isn't too bad with stock springs. Having the front alone dropped gave the car a much better look... so to answer your question, I think it's okay to change the front only, but if it was up to me, i'd do all four.
I ran this way for almost a year. H&Rs up front stock int he rear. Worked fine.
H&R front Stock rear, stock struts, 235/40/18 tires (Go 255/40/18 it fills the gap better and the ride is soooo much better)
So you didn't have an increase in understeer with a stiffer spring rate up front?
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
