Bad electronic motor mount?
Old Dec 17, 2011 | 01:13 PM
DennisMik's Avatar
I saw oil spots under my car and as I looked over the engine area, it looks as if my front motor mount is the thing that is leaking. The oil is a medium brown color, definitely not my dirty black engine oil.
Can anyone confirm that the electronic motor mounts are oil filled? I have never seen anything describing the make-up of these beasts. In the meantime I'm pulling a safety and un-plugging the thing.
Old Dec 17, 2011 | 01:22 PM
cjandura's Avatar
Yes the electronic ones are fillrd with some nasty fluid.
Old Dec 20, 2011 | 07:44 AM
Rods03Max619's Avatar
Never knew that, im bouts to do my motor mounts in Jan. but going to do the ES inserts...GL with yours...
Old Oct 15, 2012 | 07:05 PM
HonaDavis's Avatar
Motor mounts break because of aging and use. The rubber is susceptible to dry rot from the constant changes in temperature in the engine compartment(see engine motor mounts). Often the mount might not look broken if it has leakage but it cannot do its job if there is no oil inside. But to check if the motor mount is damage, try checking the exhaust manifold or valve cover gaskets. For leaks check the head pipe that joins the manifold. If there is a leak this is a sign of a bad motor mount. This needs a replacement. The leakage often is a result of excessive engine rocking that causes engine pipe connection to loosen.
Old Oct 16, 2012 | 08:46 AM
DennisMik's Avatar
Old Oct 16, 2012 | 09:47 AM
Shift_A32B's Avatar
If anything, just switch to a non-electric motor mount. Cheaper and less hassle.
Old Oct 16, 2012 | 10:14 AM
gapboi210's Avatar
Copy and paste much?
matts95max
Apr 23, 2025 10:44 AM
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
