Thermostat Replacement Write- Up
Old 01-11-2012, 07:30 PM
maximaboy12's Avatar
Hey Guys since I have not seen a thread like this and thought maybe some nOObs will like to have something like this. This fix is not hard be prepared to get dirty.
Tools Needed:
1. Small Ratchet set with a swivel head. (Preferably) 10mm
2. Pan or something to catch the coolant.
3. Pliers
4. Flat Head Screwdriver
5. Flashlight
Step 1: Let your car cool down. DO NOT open the cap while the engine is hot.
Step 2: Take off the radiator cap. Once the car is cool unplug the coolant reservoir.
Step 3: Start to take of the 2 hoses attached to the T-Stat. You will need the pliers to take off the clamps and a flat head to slide off the hoses.
***** There are 2 ways to do this you can either flush your coolant
or do like I did and just open up the hoses and catch all the
coolant in a pan underneath the car.*****
Step 4: Remove all the bolts holding the T-Stat in.I believe there are 3. This is were the ratchet comes in. It really would be good if you have a smaller set with a swivel head.
**** The Third Bolt is under this elbow****
Step 5: Take out the T-Stat and replace with new one and the new gasket dont forget to put a lil sealent on the gasket. A new OEM T-Stat on ebay runs for about $25 Bucks shipped.http://www.ebay.com/itm/NISSAN-MAXIM...item35b40ab64d Installation is the reversal of removal.
Step 6: Refill your radiator. If your coolant has bits and lil pieces of trash pour new coolant in. You dont want that crap in your engine.
Step 7: Turn the car on and blast the heat. Check for leaks.
maximaboy12 is offline
Old 01-11-2012, 07:53 PM
BigLou55's Avatar
nice write-up, should be a sticky
BigLou55 is offline
Old 01-11-2012, 08:05 PM
chrome91's Avatar
dont forget you have to bleed the system, even if you just replace the thermostat and lose ~1L of coolant
other thing is clean around the thermostat housing where the gasket mates to the surface with a razor blade
chrome91 is offline
Old 01-11-2012, 08:10 PM
True. Sorry I forgot...just thought those were a given. Lol
Old 01-23-2012, 07:05 PM
hey thanks man
Old 01-24-2012, 03:09 AM
a.k.a. STuNtMAN
JonBlz's Avatar
nice and simple write-up......i would use rtv and then slap the gasket really secure it with any type of leak
JonBlz is offline
Old 01-24-2012, 04:08 AM
Originally Posted by JonBlz
nice and simple write-up......i would use rtv and then slap the gasket really secure it with and type of leak
exactly what i did. I just dont write that here because I dont think that the noobs are that bad but ill write it in....oh and thanks man
Old 01-24-2012, 04:22 AM
a.k.a. STuNtMAN
JonBlz's Avatar
lol you will be surprised
JonBlz is offline
Old 01-24-2012, 08:33 AM
dot dot dot ...
NmexMAX's Avatar
Co-Signed and
Stickied.
http://forums.maxima.org/5th-generat...n-how-diy.html
NmexMAX is offline
Old 01-25-2012, 03:53 AM
a.k.a. STuNtMAN
JonBlz's Avatar
will be replacing my friends thermostat today or tomorrow
JonBlz is offline
Old 01-25-2012, 04:06 PM
unrealii's Avatar
There is also a water control valve which operates like the t-stat. I dont know about the longevity of them, but I replaced it with my t-stat when I did my radiator.
unrealii is offline
Old 04-20-2014, 02:16 PM
AWeb80's Avatar
Where are the bleeder screws on the cooling system?
AWeb80 is offline
Old 04-20-2014, 02:38 PM
maximasicilian123's Avatar
Just take the cap off and let it run for about a hour. Make sure reservoir and radiator is full. Try doing it where ur car would be on a incline like a hill.
maximasicilian123 is offline
Old 07-28-2014, 08:59 AM
619MAX's Avatar
Is this for the 3.0 or 3.5? I have a 4th gen and am looking for a thermostat write up like this for the 3.0, thanks
619MAX is offline
Old 07-28-2014, 09:16 AM
tosheto's Avatar
I am sure the design is similar, if not exactly the same.
tosheto is offline
Old 01-02-2015, 05:37 PM
noaksx3's Avatar
Does this thermostat assembly come with a gasket? I bought one today at Autozone, and they said it didn't have a gasket with it.
noaksx3 is offline
Old 01-02-2015, 05:53 PM
Bad *** Newb
Child_uv_KoRn's Avatar
autozone....yeah, this won't go horribly wrong
Child_uv_KoRn is offline
Old 09-15-2016, 08:49 PM
PopularWithVertigo's Avatar
This is a great post and it saved my **** back in May... I would go a step further and say that a swivel head for the ratchet isn't just recommended but that it is absolutely necessary. The bolt underneath the elbow is nearly impossible to get to otherwise.
PopularWithVertigo is offline
Old 09-15-2016, 09:11 PM
Bad *** Newb
Nope, OP did it wrong. You loosen the tensioner pulley, slip off the belt, and tighten the adjustment nut all the way down, then you have full access to the bolt. Easy peasy.
le sigh, nubs gonna nub
Old 09-16-2016, 07:18 AM
Reallyslowrio's Avatar
meh, I did it without a swivel or messing with the belt.
I had to use a combination of shallow/deep sockets and a tiny extension I had laying around to get all of the bolts.
Reallyslowrio is offline
Old 05-31-2019, 05:48 PM
drnds's Avatar
Help picture show
Where does this hose go to ? and part number for it please ASAP
drnds is offline
Old 06-01-2019, 01:41 PM
tri-valley mechanic's Avatar
It's the coolant return hose coming off the oil cooler:
It connects to the other end of the metal line that comes off this port on the oil cooler:
Sorry it took so long for anyone to respond to this.
tri-valley mechanic is offline
Old 06-01-2019, 01:45 PM
drnds's Avatar
Thankful to you
drnds is offline
TravisCadello
61
02-22-2021 07:35 AM
Goomz
09-22-2010 07:36 PM
OhOhMax
06-03-2010 10:00 PM
95maxing
01-20-2005 07:18 PM
maximus_pr
08-29-2004 10:58 AM
Quick Reply: Thermostat Replacement Write- Up
