Negative camber = better cornerning????
Old Jan 1, 2002 | 09:16 PM
RBa's Avatar
RBa
Just curious...
Old Jan 1, 2002 | 09:22 PM
Sprint's Avatar
parbroiled? or Uncle Bens?
Old Jan 1, 2002 | 09:24 PM
RBa's Avatar
RBa
Sprite!!!
Old Jan 1, 2002 | 09:49 PM
Driven EF9's Avatar
Re: Negative camber = better cornerning????
Originally posted by RBa
Just curious...
depends.
Old Jan 1, 2002 | 10:08 PM
Loe max's Avatar
Re: Re: Negative camber = better cornerning????
Originally posted by Driven EF9
Depends.
the diapers?
Old Jan 1, 2002 | 10:17 PM
Maximam's Avatar
Just curious...
Yes to a point. I run 1.5-2.5 degrees neg camber on my 510. All a combo of springs,shocks,swaybars,tires and camber.
Mark
Old Jan 1, 2002 | 10:19 PM
Jeff92se's Avatar
I'm needing a caw
Whoa! 2.5 deg neg!?! Say by-by to tire wear!
Mark
Old Jan 1, 2002 | 11:33 PM
AznWontonboy's Avatar
Re: Re: Re: Negative camber = better cornerning????
you mean hello tire wear right? I had a friend with coilovers and never got camber plates.. hehehe.. his tires looked nice from our view, but when he went under to do some maintenance.. you see worn at metal strips..
Old Jan 2, 2002 | 04:50 AM
UMD_MaxSE's Avatar
Got Bent?
just make sure your tires don't look like this:
Old Jan 2, 2002 | 06:44 AM
wdave's Avatar
Just curious...
For road racing on radials as much as 3 deg static negative camber is normal, just look at a F1 or Indy car set up for road courrses. For street that's too much - you don't spend enough time cornering so inside edge tire wear would be extreme. I'd guess 1/2 to 1 deg would be a nice compromise for street use. Note - the Max rear has negative camber built in (more guaranteed understeer).
Old Jan 3, 2002 | 11:37 AM
got rice?'s Avatar
I run -2.5 in the rear of my CSP Miata.. tire wear isn't an issue on such a light car
To answer the original question, yes, more neg. camber allows for more tire to be in contact with the surface while cornering *but* lessens high speed stability if it is too excessive. As the front wheels are turning, you will get positive camber (not good) so by having negative camber to counteract it.
Use this picture as a visual: http://www.imagestation.com/picture/...b.jpg.orig.jpg
By running a little neg. camber, it prevents the outside portion of the driver front tire from scrubbing. If this Austin Healey was running more pos. camber, you'd see more of the middle and outer tire scrubbing but with the current camber setting, the whole tire is in contact with the surface.
matts95max
Apr 23, 2025 10:44 AM
adamgalazka
Sep 8, 2015 01:27 PM
Balkins
Aug 12, 2015 06:39 AM
