My Key Broke
Old Jan 19, 2012 | 12:53 PM
stockmax's Avatar
My Key Broke
I dropped my keys and the plastic piece that goes through the key ring broke. Now, I can't hook the key to the remote or to my other keys. I tried to super glue it back, and it lasted about two days, then broke again. Do I have to replace the entire key, or is there something I can buy to slip over the key to fix this? 2000 Maxima SE.
Thanks in advance.
Keith
Old Jan 19, 2012 | 12:55 PM
03VQMAX's Avatar
Get a new key, they are inexpensive.
Old Jan 19, 2012 | 01:18 PM
Shift_A32B's Avatar
Yeap, go to the dealer and ask for a new one. They'll need your VIN number. Cost me $28.xx with tax. The new sure looks better than the copy key the last owner gave me. So now I have one original key + 2 copy keys.
Old Jan 19, 2012 | 01:35 PM
smokin5s's Avatar
I'm glad I read this post, I went to get a key cut today and was told I couldn't because there's a chip in it and was dreading calling the dealership.
Old Jan 19, 2012 | 01:42 PM
stockmax's Avatar
The key is inexpensive. Programming it isn't. Haven't called the dealer to verify, but I believe I will be out about $100 to $150 or so for new key and re-programming of all of the keys.
Other ideas out there? Anybody know of someone that makes a slip-on cover?
Keith
Old Jan 19, 2012 | 01:48 PM
Cut up an eBay remote cover, slip your key in and glue it. **** it.
EDIT: Or epoxy the broken piece back on.
Old Jan 19, 2012 | 01:55 PM
BigLou55's Avatar
new nissan key on amazon for about 20-30 bucks and dealer charges about 40 to program.
Old Jan 19, 2012 | 02:04 PM
smokin5s's Avatar
so the key will be 70 dollars?
Old Jan 19, 2012 | 02:36 PM
cjandura's Avatar
You can remove the RF chip out the bottom of the key and stick it in the new one.
Old Jan 19, 2012 | 08:12 PM
01maxium's Avatar
I bought a new key and it cost me $62 because I have a chip.
Old Jan 20, 2012 | 01:15 AM
DennisMik's Avatar
If just the thin bar of plastic broke, you could drill a hole in the head of the key.
Old Jan 20, 2012 | 02:41 AM
RR5's Avatar
RR5
Takes patience but take two part epoxy and a paper clip. Keep trying to get the epoxy to bridge the break in the plastic loop. After a while, you'll get it started and built up. It'll last a little while.
I did this for a alarm/remote that broke in a similar place. The epoxy lasted a few months until I said #&@k it and bought a new one.
Old Jan 20, 2012 | 03:06 AM
zzmmrx0xmzz's Avatar
This is what I used. I had an eBay flip key, just get your eBay key cut, remove the chip in the key, and swap the remote. Sadly I broke mine cause I threw it at a tree one time when I was mad
Old Jan 20, 2012 | 06:31 AM
TallTom's Avatar
You can try this: get a regular key cut for like $5 and then just leave the broken chip piece in the car at all times. Not sure if it needs to be near the steering column or if you can get away with leaving it in the center console. Worst case, just leave it attached to the keyring.
No one outside the car would know that you have it in there.
Old Jan 20, 2012 | 06:54 AM
03VQMAX's Avatar
Key on ebay, $10, Cutting, $10, Programming $50. That was my total when I first bought my car and needed a spare...
Old Jan 21, 2012 | 07:41 PM
stockmax's Avatar
This is what I have done until I get around to buying a new key.
Thanks,
Keith
Old Jan 21, 2012 | 07:51 PM
Aorcer's Avatar
i actually broke my main key last night and my other original chip was fried but i just taped the two together and the second key now starts the car...as long as a key that works is near the key it will start and run properly
Old Jan 22, 2012 | 08:27 AM
BigLou55's Avatar
OP this is the exact key I have have for my car right now and its works fine...dealer charge me 39 bucks to program it and cut it for free.
http://www.amazon.com/2000-Nissan-Ma...7249434&sr=8-8
Old Jan 22, 2012 | 08:48 AM
mrjasonlyrics's Avatar
Look on ebay man. They should have something that you can buy to replace your existing shell case.
Old Jan 22, 2012 | 09:36 AM
BigLou55's Avatar
yup
Old Jan 22, 2012 | 12:34 PM
stockmax's Avatar
Saw the exact same thing on ebay for less than $10, free shipping. Going to order one this week. Hope my dealer is as reasonably priced as yours, my experience is that everything takes at least an hour, at $90 or more.
Keith
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 16, 2015 02:53 AM
jerrod99_se-l
Sep 19, 2015 06:54 AM
dcam0326
Sep 18, 2015 04:52 PM
