2K2 SE - CD skipping
Old Jan 2, 2002 | 07:32 AM
haylo75's Avatar
Hey guys, I've had a 2K2 SE with the premium audio package since early Oct. 2001. The CD changer didn't skip once until I got in the car the other day when it was ~15 degrees out and it skipped like mad for about 20 minutes. The problem seemed to clear itself up and I haven't been able to duplicate the issue again. Anyone else have an issue like this?
Thanks,
Kerr
Old Jan 2, 2002 | 08:17 AM
BioMaxDDS's Avatar
Me too. I had my car since oct. and about 3 nights ago, all of sudden my cd player start skipping too for about 30 mins. the next day, everything was ok again. and ya....it was freezing cold outside too
Old Jan 2, 2002 | 09:58 AM
bigbadboss101's Avatar
I noticed that when it is below -10 celsius here. Also, random mix play the same sequences
Old Jan 2, 2002 | 10:11 AM
irvine78's Avatar
Re: 2K2 SE - CD skipping
Thanks,
Kerr
just bring it back to the dealer...let them worry about it..
MichaelAE's Avatar
Maybe the warranty just ran out.
Old Jan 2, 2002 | 10:38 AM
Colonel's Avatar
Old Fuddy Duddy
Condensation?
Maybe it that. Cold weather, car warms up and cause it to skip until its clear. I have problems with moisture in general in my car. Do you have to run the defrost almost constantly until the car warms up?
Old Jan 2, 2002 | 11:51 AM
nice95GLE's Avatar
Service guy said the cold temps causes the CD player to skip every now and then. I wouldn't be concern.
Old Jan 2, 2002 | 01:04 PM
MONTE 01&97 SE's Avatar
My 02 has done that also, and sometimes changes tracks on me when I hit a bump!
Old Jan 2, 2002 | 03:14 PM
BioMaxDDS's Avatar
this is the first car that has this problem for me. do you guys think nissan will replace it for me?
Old Jan 2, 2002 | 03:42 PM
B1GMATT's Avatar
Mine skips too when I leave it outside overnightin the cold, usually I keep the car in the garage. One thing I noticed is that one time it skipped a little, so I took the CD out to see if it was dirty. The CD had a little moisture on it. Moisture in a CD player can't be good. Anyway, After I cleaned the moisture off it worked fine.
Also, is this happening only with the BOSE systems? or do some of you have the single CD player and it skips as well.
Old Jan 2, 2002 | 03:49 PM
BioMaxDDS's Avatar
I have the regular stereo system
I changed all the speakers, added amps & subs, but kept the factory headunit, do you guys think dealer is gonna give me some crap about the aftermarket stereo equipments, if i tell them to fix it or put in a new one?
Old Jan 3, 2002 | 11:37 AM
haylo75's Avatar
I didn't check for condensation because the car was garaged right before my problem cropped up. If it happens again, I'll definitely check. I am also curious as to whether this problem is only afflicting the Bose 6 CD changer systems or also the base cd players.
Old Jan 4, 2002 | 06:49 AM
MAXIMA2673's Avatar
The manual explains that this will happen if moisture gets in to the CD rack.It has only happened to me once when it was like 22degrees out. It lasted for about 10 minutes util the car got warmed up.
Old Jan 4, 2002 | 07:12 AM
2MAX's Avatar
Definetely a moisture problem...Remember, CD player has a laser reading the little holes on the CD and translates that into music... So if moisture prevents the correct reading, synch is lost and it jumps...
I live in Montreal (pretty cold per US standards... ), I don't have a garage and my Max never had this problem in 2 years (GXE with upgraded sound system, not the Bose though
TallTom
57
Oct 14, 2025 05:16 PM
cruce91
Sep 20, 2015 10:23 AM
Shayyadin
20
Jun 27, 2001 02:10 AM
Shayyadin
May 27, 2001 08:33 PM
ericdwong
May 26, 2001 11:32 PM
