15k Service
Old Jan 2, 2002 | 10:07 AM
tomz17's Avatar
15k Service
Time for 15k service on my 2k SE...
Anywayz, the dealer wants 255.65... ya right!!!
I figure i'll just pick out oil/filter change (21.95) + fuel filter replacement (49.95) + air filter replacemenet (19.95) off their "menu"
(the only other important thing looks like tire rotation, but I had that done at close to 10,000.... everything else is BS inspections and such... ie. they want me to pay them $29.95 to inspect the brakes, etc.)
My question is, how much do the fuel filter and air filters cost? How hard is it to replace them yourself? (i'd imagine the air filter would be pretty easy).
suggestions?
-Tom Z.
PS. Anyone know what "minor automatic/manul transmission service" means? at 15,000 miles!?!?
Old Jan 2, 2002 | 10:10 AM
eortiz15's Avatar
Re: 15k Service
Get the K&N drop in and you won't have to replace it for the
life of the vehicle. Just clean it every 50,000 miles.
K&N runs for about $45 to $50 @ local parts store.
Old Jan 2, 2002 | 10:11 AM
tomz17's Avatar
Re: Re: 15k Service
Sounds like a plan!!! almost overlooked that possibility... thanx!!
-Tom
Old Jan 2, 2002 | 10:24 AM
UMD_MaxSE's Avatar
Got Bent?
just curious, how are you going to replace the fuel filter? On the 5th gen, it is located as a part of the fuel tank.
Old Jan 2, 2002 | 10:29 AM
tomz17's Avatar
really?? I dunno, it's listed in the Service menu that I got from my nissan dealer, and they want to charge $50 for it.. (from searching on this board it looks like someone else got charged for it too!!)
http://forums.maxima.org/showthread.php?threadid=87472
What do you think? is my nissan dealer trying to rip me off??
is the fuel filter non-serviceable?
-Tom Z.
Old Jan 2, 2002 | 10:31 AM
UMD_MaxSE's Avatar
Got Bent?
thats what the user manual and the FSM say... look it up just to make sure though....
Old Jan 2, 2002 | 10:46 AM
CIRCO's Avatar
Re: 15k Service
Don't forget about the brakes, and they are probably charging you for some sort of flush. They always suggest it whenever they get a chance.
suggestions?
-Tom Z.
Old Jan 2, 2002 | 10:57 AM
tomz17's Avatar
Re: Re: 15k Service
Well, what exactly is the brake inspection, other than them just looking at it???? personally, i don't think it sounds all that important. I've never had issues with my brakes. No warped rotors (knock on wood), and my car grips the road like glue when you mash the brake (on my stock tires, thats good enough inspection for me)
They don't want any kind of flush this time around... (coolant drain/flush/refill is listed at 30k)
-Tom Z.
Old Jan 2, 2002 | 11:04 AM
CIRCO's Avatar
Re: Re: Re: 15k Service
-Tom Z.
I agree it's insane that they do it but apparently they get a measurement of how much "meat" is left which they could do by looking at it. I was just giving you some justification as to why they might be charging you that outrageous price. Did you get anything on the fuel filter. I am right at 15K and was looking into service at the dealer, but they wanted 350. I said forget it and put it off till I moved back home.
Old Jan 2, 2002 | 11:14 AM
PCGuRu2K's Avatar
You really don't have to worry about service till you get around 60K.. For now just oil change, air filter is good enough.. When you hit 30 get the flush of tf, and anti-freeze.. Maybe spark plugs if you want...
Old Jan 2, 2002 | 11:18 AM
sleepermax's Avatar
Don't they also do a fuel rail flush and put in fuel injector cleaner?
Old Jan 2, 2002 | 11:19 AM
tomz17's Avatar
Ya... i think i'm just gonna go for air filter (maybe K&N), and have them do the oil change.. (it's a lot less messy to have them change my oil.. and hell, for $20 I think it's worth it..)
-Tom Z.
Old Jan 2, 2002 | 11:21 AM
tomz17's Avatar
It's not on the list, but perhaps this is what they meant by fuel filter replacement... I dunno, I'll ask them when I go in tomorrow..
-Tom Z.
Old Jan 2, 2002 | 11:30 AM
dougb's Avatar
Re: 15k Service
Tom,
I look at the manual when it comes to services, and then deterine what I want to do. Screw the dealer and their service pamphlets. At 15,000 I needed an oil change, air filter, tire rotation...That's it.
For the 30,000 service I changed the oil, air filter, and all fluids....tranny, brake, and radiator. The dealer wanted 450.00 for this service, I shopped things around and had the stuff listed done for about $195.00.
The fuel filter never needs to be replaced according to the owners manual.
Good luck and don't let them take you for a fool.
suggestions?
-Tom Z.
PS. Anyone know what "minor automatic/manul transmission service" means? at 15,000 miles!?!? [/B][/QUOTE]
Old Jan 2, 2002 | 04:43 PM
Y2KMaxGXE-R's Avatar
Well, what exactly is the brake inspection, other than them just looking at it???? They don't want any kind of flush this time around... (coolant drain/flush/refill is listed at 30k)
-Tom Z.
they check for wear on your brakes, measure how worn your parts are. If they tell you brakes need replacement, don't agree right away. Ask them to put down in writing the results of measurements (thickness of pads/rotors?), VS. OEM standards...my 15K service cost me $35 (oil/filter change+rotation)..you don't need to replace your air/fuel filters at 15K mi, no radiator flush, no fuel treatment, no cleaning of throttle body or tune-up needed. It is a great shame that mechanics are so damn greedy and try to rip everyone off.
Old Jan 2, 2002 | 04:50 PM
tomz17's Avatar
Re: Re: Re: Re: 15k Service
Nah, I was never planning on letting them "inspect" anything... I'll prolly just have them do the oil change, and go for the K&N drop in... I'll check on the fuel filter situation (check my manual[in car] , and see what they say).
-Tom Z.
Old Jan 2, 2002 | 05:00 PM
TimW's Avatar
The silent but deadly Moderator
the fuel filter...
From what I know, the fuel filter is located in the tank with the pump and sensors. access to it would be through back seat. I have no clue how you would depressurize the lines... but I could see a hellava mess in the making, albeit access to the filter can't be that hard. You're in FSM country now. Maybe get the FSM and 'offset' that cost of going to the dealer. I mean, it could be the mechanics first one to do too.. and your car could smell like a tanker forever. I dont know that, but it seems possible.
Old Jan 2, 2002 | 05:35 PM
tomz17's Avatar
Re: the fuel filter...
Hmm... well, i definitely don't think that's what they had in mind for 15k service ... i'll ask tomorrow
-Tom Z.
Old Jan 2, 2002 | 06:05 PM
woosh's Avatar
for the tire rotation
For the tire rotation , does anyone know the pattern
if I have:
FL FR
RL RR
after rotation is it?
RL RR
FL FR
Old Jan 2, 2002 | 07:08 PM
MaxDriver98's Avatar
My car has 15500 miles and I am still debating on if I should do it myself or go to the dealership. I doubt the extra 500 miles cause damage.
Old Jan 2, 2002 | 07:20 PM
maximaman69's Avatar
Re: for the tire rotation
[QUOTE]Originally posted by woosh
if I have:
FL FR
RL RR
RL RR
FL FR
[/QUOTE ]
My understanding is that it should be:
RR RL
FR FL
That way, if you are using tread on the outside of your tire, it will now be on the inside where it will be worn less.
Old Jan 2, 2002 | 07:38 PM
damn, your car is 4 yrs old and you only got 15K mi on it...do you drive anywhere?
Old Jan 2, 2002 | 08:34 PM
I bought it with 9,000 miles on it 5 months ago
Old Jan 2, 2002 | 08:51 PM
TimW's Avatar
you only swap front to rear...
its in the manual. its not the best for wear, but helps you not have belt separation or slipped/pulled belt. You're car will handle like unicycle with a flat if a belt slips.
my03maxima
Jul 28, 2024 07:40 AM
14GmMax
59
Aug 4, 2019 11:26 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
Max8
Sep 22, 2015 02:53 PM
