po507 what to do
Old Feb 6, 2012 | 08:05 PM
bryanakaslim's Avatar
po507 what to do
i just got the code po507 but my maxima idles fine i tried idle relearn but nothing happen
Old Feb 6, 2012 | 09:07 PM
DennisMik's Avatar
According to the FSM, the code P0507 is either the electric throttle control actuator or an intake air leak.
Old Feb 7, 2012 | 09:57 AM
gsjohnson's Avatar
P0507 is most likely the Idle Speed Control Unit. The relearn will not do any good until you replace this part. Very common failure. Do not keep driving your car with this failure as it will begin to take out other parts with it.
Old Feb 7, 2012 | 01:16 PM
if i get a tb will it fix it
Old Feb 7, 2012 | 03:21 PM
NmexMAX's Avatar
dot dot dot ...
Not sure if this is relevant with the 02+ though.
OP, does your car go into fail safe mode? If not, it is most likely an air leak.
Old Feb 7, 2012 | 09:52 PM
no it just idles high now 1200 when it strarts up and 900 when it warms up i called nissan no Idle Speed Control Unit in car
Old Feb 8, 2012 | 06:46 AM
NmexMAX's Avatar
dot dot dot ...
In the case of the 02+, it's the throttle control actuator. I wouldn't be so fast to go and buy a new TB.
Have you don anything to prompt this behavior, (anything related to the intake/MAF, manifold, and most importantly, TB).
I've changed my plugs a time or 2, and cleaned the TB and done spacers and removed them IM plenty of times, sometimes It takes a few relearns to actually work. IAVL and all associated "relearns".
se_nismo
Jul 11, 2010 02:06 PM
CJLax
Dec 2, 2008 10:40 AM
ChrisG
Nov 22, 2006 12:24 PM
