gauge problem
Old Feb 10, 2012 | 06:08 AM
sergey85's Avatar
gauge problem
hello my problem is the milage on the gauges. it started about a month ago and the last numbers stopped working. its not showing tthe numbers after the period. searched around to see if i can get the se cluster but seems like alot of work. if i were to get the same as my oe how would i go about get the milage corrected? also my temp buttons(by the radio) dont light up but i think i ccan replace that. anyone can help i appreciate, thanks
Old Feb 10, 2012 | 10:27 AM
fishtale6spd's Avatar
Your mileage is recorded on your bcm not the cluster itself so replacing your cluster with a new or used one will not change mileage at all also the temp leds prolly just burnt out you can just solder new ones into there
Old Feb 10, 2012 | 11:00 AM
cjandura's Avatar
You might want to check with tunermax3000 he knows about our clusters more then anyone on here.i thing
Old Feb 11, 2012 | 04:42 AM
sergey85's Avatar
thank you
Old Feb 13, 2012 | 06:10 AM
RICHIEBXNY's Avatar
^^^^^^mileage is not stored on bcm on 5th gens its stored on the cluster its self , i have changed my cluster 2 times and came up with the milage from the cluster
Old Feb 16, 2012 | 01:21 PM
bocian's Avatar
+1
Mileage is stored on the cluster itself
My guess is getting it reprogrammed at a dealership with your current mileage or maybe theres a way to take it apart and change the necessary parts, hopefully someone can chime in on that idea
Old Feb 16, 2012 | 01:24 PM
djfrestyl's Avatar
Suspension Yoda
Needs to be programmed or IIRC soldering is involved.
The bulbs on the HVAC can be replaced. No soldering necessary.
Old Feb 16, 2012 | 01:48 PM
BigLou55's Avatar
there is a chip on the on cluster circuit board that records the mileage...get another working cluster remove the chip and solder it on the new circuit board and you will have saved your mileage...tunermaxima has photos on the org of this chip and its location
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
BrandonCause
Sep 14, 2015 10:41 PM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
