Whine when turning (video inside)
Old Feb 17, 2012 | 10:27 AM
Gizm0's Avatar
Hello,
My car has been doing this whining sound when the wheels are turned and I press on the gas. The video below shows what it sounds like.
It only happens when i got my foot on the gas, even very slightly. If I take it off, nothing. It happens when the steering wheel is turned more than 1/3 of a turn (left or right).
Any idea what it could be?
I was thinking the differential? I replaced the tranny fluid and it hasn't improved any...
Old Feb 17, 2012 | 10:47 AM
cjandura's Avatar
kind of sounds like the pass side rear caliper locking up.
Old Feb 17, 2012 | 10:55 AM
luvlexus101's Avatar
Does it happen when you're stopped?
Gizm0's Avatar
cjandura >
No, only when i'm in gear and the car is moving
Old Feb 17, 2012 | 11:53 AM
T_Behr904's Avatar
power steering pump?
Old Feb 17, 2012 | 12:10 PM
Gizm0's Avatar
It doesn't sound like a power steering pump. My neighbor's 02 max needs a new PS pump, and the whine is very different.
My other two guesses would be a wheel bearing, or cv joint?
PS: The noise comes from the front of the car.
Old Feb 17, 2012 | 12:17 PM
cjandura's Avatar
did you recently lower the car?if you did make sure your axles are popped in completly
Old Feb 17, 2012 | 12:21 PM
Gizm0's Avatar
The car was lowered 6 months ago, but the sound started before I lowered it. It gradually became louder over a period of a month, and then leveled out. It's been loud like in the video for over a year now i'd say...
Old Feb 17, 2012 | 01:04 PM
The6spdMax's Avatar
Yeah, the noise does sound kinda strange... Have you check the list below?
Front end noise?
Check these in this order...
Stabilizer link, Sway bar bushing, Strut mount, Strut, Tie rod/ball joint (based on 3-9 or 6-12 tests), Motor Mounts
If those dont solve your problem, it'll more than likely be axles, wheel bearings, or something bigger.
Old Feb 19, 2012 | 12:00 PM
fatboyslim86440's Avatar
Make a video with out you turning...
Old Feb 19, 2012 | 12:11 PM
Gizm0's Avatar
There is no whine when I'm not turning.
Old Feb 22, 2012 | 08:07 AM
Gizm0's Avatar
Here is another one... this time the wheels are straight. I've got one wheel on the snow, the other on the pavement, and the handbrake up.
Differential is damaged?
bryants95max
Oct 2, 2015 12:52 PM
rnb754
Sep 14, 2015 11:39 PM
LtLeary
Sep 14, 2015 12:33 PM
Maxxx10
Sep 13, 2015 03:16 PM
