AE passenger axel replacement trouble!!!
Hey all. I'm in the process of replacing the passenger axle on my 2001 AE. I know the axle is attached to that bearing with 3 12mm bolts on it. My issue is that I was able to get the bottom two bolts out but no way on the top on. I removed a big piece of heat shield off the factory y-pipe. And still and can't get to it. I've searched and can't come up with anything besides "have to take off the 3 bolts on tr bearing". Is there any certain way to take off the top one?? I could remove the factory y-pipe and get to it. But never heard of anyone doing so to change the axle. Help please!!
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
The top one is tricky if you've never done it before. Use a ratcheting wrench. Don't go from underneath, go from the side of the car. (face the hub) Reach in and feel for the bolt, get the ratchet wrench on there and pull up. If you don't have enough leverage, use the trick where you attach another wrench to the end to gain some more leverage.
Worse comes to worse, just take off the entire thing. It's just 2 bolts (14mm if i remember correctly) attached to the block.
Of course Essential can step in he knows this procedure back to front
Yea I felt the bolt by going in from the side. My problem was no leverage because of the o2 sensor. I know that had I a aftermarket y-pipe It would be soooooo much easier. I'll give it a shot again and check back. Thank!
The boots move constantly in and out and up and down and around. No sealant is going to work.
When I did my 4th gen way back in the day, I just pulled the whole bracket down and then swapped the hanger bracket over on the bench (driveway, whatevs), that's what you're trying to do?
MattWithTheMaxima
06-30-2017 01:06 PM
Starrider
09-17-2015 07:26 AM
CAN-Other LF: Worn / Broken Parts
george__
08-18-2015 07:06 PM
MikesChevelle
08-06-2015 11:36 AM
