Super FMU 4 Supercharged Maximas
Old Jan 2, 2002 | 05:46 PM
jhans114's Avatar
I was thinking of replacing the FMU that came with the Stillen Kit.
I was thinking of getting the Super FMU. Has anyone bought this?
Click here---> http://www.vortechsuperchargers.com/tech/fmu_sfmu.html
Feedback pls.
Old Jan 2, 2002 | 06:16 PM
ZIPPIN's Avatar
Mauja He Mauja
Re: Super FMU 4 Supercharged Maximas
Feedback pls.
where did u get this idea
Old Jan 2, 2002 | 07:39 PM
max'n out's Avatar
If you running stock boost no reason to change it really. If you change it you could get that but you gotta go to a good dyno shop to get it adjusted right.
Old Jan 2, 2002 | 10:54 PM
jhans114's Avatar
I agree. I ran stock boost and when I dynoed my car after a certain rpm my fuel got really lean. So im gonna run 2 pulley sizes smaller, custom intercooler and thinking of getting the superfmu and see the results. Well no one has any info then I guess I'll be the first!
Old Jan 2, 2002 | 11:33 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Your fuel was lean? You shouldn't go lean on stock boost with the 6:1 disc.
No need for a Super FMU unless you want to fine tune your fuel. A 8:1 disc should suffice.
I can't answer your PM's becaues your box is full.
Old Jan 2, 2002 | 11:38 PM
jhans114's Avatar
Thanks for the info! And I cant delete my PM list cause there are no messages in it. But it says I have it full.? Could use some help.
Old Jan 2, 2002 | 11:42 PM
Y2KevSE's Avatar
No problem.
Click on profile, edit profile, select show all threads, go back into your PM box, delete old messages.
Old Jan 3, 2002 | 12:01 AM
jhans114's Avatar
No problem.
You dont think that fine tunning my fuelwith the SuperFMU would be a good thing since my friend is gonna tune it on a dynojet? Its just that my fuel chart was fine then it ran really lean. My torque was about 234lbs and about 245hp. My friend said that if we could keep the fuel graph even till the end of the run that I could gain about 10hp. Im gonna go with 3.33, ApexiSFC(even though people say that the computer will learn the settings, and the FMU upgrade. The only reason that I wanted the SuperFMU is cause it was adjustable. What would you do??? thanks for the info.
Old Jan 3, 2002 | 12:16 AM
Y2KevSE's Avatar
Can you post your dyno plot up? What is really lean? 14? 13?
I ran rich with 8:1 with 11 psi on my dyno. Jane ran rich on the 3.25 with 8:1. I don't know why you ran lean... when did this start happening? Near redline?
You can use the S-AFC to tune your a/f. I believe Keven97SE said to set the hi throttle at about 41% so the ECU won't readjust the a/f. I haven't found the need to get the SuperFMU yet...
Old Jan 3, 2002 | 08:13 AM
max'n out's Avatar
If you really want to fine tune it get the 8:1 then the hks super afr...i think thats what I'm gonna get. Check out my other post about it all the info is in the first post by me.
http://forums.maxima.org/showthread.php?threadid=88413
Old Jan 3, 2002 | 12:59 PM
jhans114's Avatar
I'm thinking of getting the 8:1 then since everyone says that the Super FMU is not worth it, but I ordered the Apexi SAFC. I didnt know that HKS made one for our cars. Do you think the Apexi one will work?
Old Jan 3, 2002 | 01:03 PM
max'n out's Avatar
Yeah. it's just not as tunable as compared to the hks says it is.
Old Jan 3, 2002 | 03:10 PM
jhans114's Avatar
Sorry my mistake I ran really RICH. Got it mixed up.
Old Jan 3, 2002 | 08:15 PM
Y2KevSE's Avatar
10 to 1?
Goffery2uned
Aug 21, 2015 09:50 PM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
