4SP question
Old Feb 22, 2012 | 03:26 AM
kurt1's Avatar
4SP question
Hay all. My Australian maxima-teana has a Abit of a thud changing from first too second gear every other gear is fine and smooth my gearbox has fresh fluid and filter plus has a big tranny cooler. It's the 4sp auto Aswell. I've seen and
Heard off lots of solenoid problems. Here in Australia I cant find those valve body kits. So I was going to buy from America. I was gonna ask if my 4SP auto is the same as your American models? I'm going to check my car tomoz and see if there's a model number on the gearbox. Cheers Kurt.
Old Feb 22, 2012 | 05:11 PM
kurt1's Avatar
Ok I found out the model number for my 4sp auto. It's RE4FO4B. Is this the same gearbox the American 4sp maxima is running? Cheers Kurt.
Old Feb 22, 2012 | 05:20 PM
CMax03's Avatar
It should be on top under the intake filter housing IIRC! Check your tag under the hood mounted on the firewall it usually includes chassis, engine and trans #'s.....
Old Feb 22, 2012 | 07:43 PM
Chris Gregg's Avatar
Get Off My Lawn
+1
The Transgo HD2 kit is great. I know I had some negative comments associated with bad experience after the install. However I later learned my issue with an overly aggressive and harsh 1-2 shift was due to a busted front electric mount. After replacing, couldn't be happier!
Old Feb 22, 2012 | 07:55 PM
kurt1's Avatar
Originally Posted by Chris Gregg
+1
Ive got the same problem my front mount the one just at the bottem of the radiator is busted and my 1-2 shift is abit rough u can feel the change. Witch transgo kit has the better oil pump-booster that includes in the kit?
Old Feb 22, 2012 | 08:32 PM
Get Off My Lawn
IDK: Just a bunch of springs and ***** to me. I don't do transmission internsls- nope!
Old Feb 22, 2012 | 08:47 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Yep, sounds like bad mounts. You can visually inspect the mounts and see that they're cracked up and split, falling apart, etc.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
