Burning oil?
Old Feb 22, 2012 | 08:40 AM
anomaly117's Avatar
Burning oil?
Hey all, have an issue as of late with my max. lately i've had to add a quart of oil about once a month, if not more often, to my engine. i haven't noticed puddles, so i'm assuming the oil is burning off somehow. thought i'd ask if there was a pattern failure on the 5.0 gens that could cause this, so i can at least look in the right direction. thanks in advance.
Old Feb 22, 2012 | 08:50 AM
NmexMAX's Avatar
dot dot dot ...
Nope, very rare for a DEK to burn oil.
You mentioned about a month, do you know of the actual mileage interval? Everything else maintenance wise seem as if it's in good shape?
Old Feb 22, 2012 | 03:07 PM
anomaly117's Avatar
that's what i thought. very rare for the 3.0. as far as mileage im not really sure, i can tell you i drive about 25 miles to and from work every day, so let's say around 1000? and yea, everything else seems fine as far as the engine is concerned.
Old Feb 22, 2012 | 03:18 PM
Rods03Max619's Avatar
Damn this is the first I here of a 3.0 with oil burning, how many miles is on the car....
Old Feb 22, 2012 | 03:34 PM
NmexMAX's Avatar
dot dot dot ...
Checking the 710 while it has been sitting overnight on a level surface?
Also, do you actual record or somehow document how much 710 you put in and how much you remove when you change it?
Old Feb 22, 2012 | 03:51 PM
anomaly117's Avatar
175k
and... 710?
Old Feb 23, 2012 | 06:22 AM
TallTom's Avatar
Originally Posted by anomaly117
175k
and... 710?
I think 710 is OIL written backwards and upside down.
Old Feb 23, 2012 | 08:05 AM
anomaly117's Avatar
hah, i see. i haven't done an oil change since this has started happening, so no.
Old Feb 23, 2012 | 08:06 AM
anomaly117's Avatar
also forgot to mention, the exhaust isn't blue... so if it is burning it isn't burning alot.
Old Feb 23, 2012 | 09:26 AM
foodmanry's Avatar
Da Roller Coaster!
Did you check under the car for any type of small leaks? I have two small leaks on my engine which aren't worth fixing just yet as one is related to a rear main seal leak.
Old Feb 23, 2012 | 11:00 AM
nsnrider's Avatar
def. check the rear main seal. it might be leaking and splashing all under your car on the highway but probably won't drip fast enough to produce a puddle when parked overnight.
Old Feb 23, 2012 | 12:45 PM
anomaly117's Avatar
ill do this. hope thats not the problem
Old Feb 23, 2012 | 12:53 PM
luvlexus101's Avatar
:/ I lose about a quart every 4 months.
Old Feb 23, 2012 | 03:09 PM
foodmanry's Avatar
Da Roller Coaster!
It is easy to spot, just look past it down the length of the car. You'll see a nice dirt/grease buildup behind it if it is leaking. This is exactly how mine looks. Not dripping enough to leave a puddle, but there is a nice stream of grease/dirt behind it.
Old Feb 23, 2012 | 10:25 PM
anomaly117's Avatar
so youre adding oil periodically too?
Old Feb 23, 2012 | 10:49 PM
BigLou55's Avatar
couldn't that also be contributed to an upper oil pan rear lip seal leak seeing as how there are right on top of each other?
Old Feb 24, 2012 | 06:50 AM
Maxgig's Avatar
It could be coming from your oil pressure sending unit. I had this problem on my 97 and a friend of mine had the same issue with his newly acquired 2000. Real simple and inexpensive fix too, good luck.
Old Feb 24, 2012 | 09:31 AM
VQP0WER's Avatar
Hell, don't most 11+ year old cars leak fluid at one point or another? I'de say you are still within limits.
Old Feb 24, 2012 | 10:31 AM
anomaly117's Avatar
i'd agree with you if i wasn't trying to sell it
Old Feb 24, 2012 | 10:32 AM
anomaly117's Avatar
thanks for all your input guys ill check all these things. i really hope its something simple.
Old Feb 24, 2012 | 12:46 PM
foodmanry's Avatar
Da Roller Coaster!
My leak is not bad enough to require me to add oil between oil changes. I'm on a 3,000 mile oil change interval.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
