Pulled this plug out of cylinder #2
Old Mar 11, 2012 | 08:58 PM
bgsl1ck's Avatar
Motor went out in the middle of a swap and pulled this pulg out of cylinder #2 someone told me rob broke any in put??????
This is whats going back in 2002 6spd
Old Mar 11, 2012 | 09:22 PM
gsjohnson's Avatar
Something was or is in that cylinder. Possibly pieces of the Cat or a throttle plate screw?
Old Mar 11, 2012 | 09:27 PM
DennisMik's Avatar
I would suggest you start by doing a compression check before replacing the plug and starting the car.
Old Mar 11, 2012 | 09:31 PM
bgsl1ck's Avatar
no cats on the car
got another motor will tear the other one down once the swap is done
Old Mar 12, 2012 | 06:27 AM
MrEous's Avatar
^ Jeff™
Damn Alex...lol
Post pics of the teardown when you get to it. I'd guess something was in it as well, maybe piston ring failure causing metal pieces to build up?
Old Mar 12, 2012 | 01:06 PM
bgsl1ck's Avatar
I don't know but I will take pictures when I open it up...
Old Mar 12, 2012 | 01:16 PM
ShocknAwe's Avatar
Is the pink bike your wknd ride?
Old Mar 12, 2012 | 01:32 PM
bgsl1ck's Avatar
That's what I riding now.....
Old Mar 12, 2012 | 02:28 PM
spock's Avatar
Now that's cute.
Sure looks like something was beating on that plug. Did it make noise when it happened?
Maybe a vias plate screw, (if you had a vias that is).
Old Mar 12, 2012 | 04:55 PM
4thGenTuner's Avatar
Ouch!
From the length of the threads, it appears to have once been a plug for a 3.5.
Somthing has made contact with that plug. My guess is it would be the piston, maybe a broken wrist pin? Rod cap worked its way loose?
In for pics of the teardown. I want to see the head and the valves.
Old Mar 12, 2012 | 05:13 PM
1swtmax's Avatar
Looks like it just needs re-gaped, then you should be good. jk
Old Mar 12, 2012 | 06:17 PM
spock's Avatar
Might have to take a wire brush to it first.
Old Mar 12, 2012 | 08:28 PM
bgsl1ck's Avatar
Yeah I'll send then to you to install....
Derrick2k2SE
Nov 19, 2015 10:14 PM
Need help
23
Oct 2, 2015 08:56 AM
chernandez1278
Sep 16, 2015 01:18 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
