VIAS silenoid
Old Mar 14, 2012 | 10:57 AM
bobalou's Avatar
VIAS silenoid
So I took my car to the dealer to find out why it was hesitating from 2000-4000 rpm. I just got a call back and they said it is because of the vias silenoid fail and not letting the right amout of air get through. Would the vias block off plate solve my problem or do I need to pay the dealer to put in the new one for 350 dollars?
Old Mar 14, 2012 | 11:18 AM
Chris Gregg's Avatar
Get Off My Lawn
If the "hesitation" is the result of a faulty vias, the yes, a block plate will resolve this issue.
Old Mar 14, 2012 | 11:47 AM
bobalou's Avatar
Yes thats what I was told and thanks for the help
Old Mar 14, 2012 | 11:50 AM
Rochester's Avatar
If the solenoid is failing, it will throw a SES code. The VIAS valve itself doesn't do this, the little solenoid does. So even if you get a block-off plate, you won't be eliminating the SES.
Just saying.
Old Mar 14, 2012 | 01:53 PM
bobalou's Avatar
there was not a ses light on
Old Mar 14, 2012 | 03:39 PM
Get Off My Lawn
Good point Rochester. I was going to mention that but didn't only because no SES light was mentioned in the original post. So, the BoP should resolve the issue.
Old Mar 14, 2012 | 06:26 PM
bobalou's Avatar
the shop showed me the solenoid located under the engine cover that was not working, should I replace the solenoid or will the BoP fix it?
Old Mar 14, 2012 | 06:44 PM
Get Off My Lawn
Obviously even the bad solenoid is telling the ecu it is connected and receiving a signal to do something.....it's just not doing it properly.
Get the BoP and you will need to keep the solenoid connected - just like everybody else.
Old Mar 15, 2012 | 05:40 AM
Rochester's Avatar
Actually, if you don't have any other mods on the car, I recommend replacing the solenoid. Unless there's something compensating for the low-end loss of torque after removing the VIAS valve, you're not going to like it.
Old Mar 16, 2012 | 12:17 PM
bobalou's Avatar
so should I get Thermal Intake Spacers to compensate?
Old Mar 16, 2012 | 12:30 PM
Rochester's Avatar
Well... yes. That's one approach.
But if you're thinking about a VIAS-delete so you don't have to buy a new solenoid, or if you're considering the BOP because it's an easier fix than otherwise, then buying Phenolic Spacers is a HUGE leap of reasoning. There is a wealth of information on these mods here in the Org. I think you should start reading up.
Or simply replace the solenoid and drive your car. Mods aren't for everyone, my young Cuban friend. Most people just want to drive and not tinker, and that's totally OK.
Old Mar 16, 2012 | 12:52 PM
bobalou's Avatar
kewl thanks and I will do some research because I would like to get alittle more power out of the car if possible.
Old Mar 16, 2012 | 07:31 PM
Ghost_54's Avatar
As stated by Rochester if the VIAS soleniod is not working you are going to throw a code so simply replace the VIAS butterfly with a block plate is not going to resovle anything ... but you said you have no SES light showing hence no code I have to ask is the SES light working? or bulb out? Knowing that the Soleniod not working will throw a code and your SES light is working just fine I have to question the shop that told you the soleniod was broken and in need of re-placing.
Old Mar 16, 2012 | 07:42 PM
kbcnd's Avatar
I had a bad solenoid and code P1800, but no light. Just throwing that out there
Old Mar 16, 2012 | 07:45 PM
Rochester's Avatar
A code reader with give the OP confidence in his mechanic's diagnosis.
Old Mar 16, 2012 | 07:59 PM
bobalou's Avatar
the tech at nissan said it had a code but it was stored and not triggering the light
Old Mar 16, 2012 | 08:55 PM
kbcnd's Avatar
Yep. Mine was pending. Replaced the solenoid and all is well. No more pending/stored code.
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Turbonut
46
Oct 21, 2015 08:28 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Dasmith
Sep 23, 2015 08:28 PM
Kalrakam
Sep 16, 2015 12:30 PM
