most intake power
Old Jan 3, 2002 | 12:20 PM
MaxPower2K2's Avatar
most intake power
did any of u guys consider taking off the intake and leaving the mass air flow sensor, isnt that suppose to give u the most power.
what do u guys think
Old Jan 3, 2002 | 12:25 PM
Colonel's Avatar
Old Fuddy Duddy
Re: most intake power
I am assuming you are thinking about leaving some kind of filter on there somewhere right? No filter = bad things for your motor.
Old Jan 3, 2002 | 12:27 PM
of course like a mesh or something of that sort,
but power wise what do u guys think.
Old Jan 3, 2002 | 12:29 PM
AznWontonboy's Avatar
No, that is still bad filtering
Old Jan 3, 2002 | 12:30 PM
what do u recomend
Old Jan 3, 2002 | 12:42 PM
PhatGuy
what do u recomend
The FrakenCar Performance Intake is the best bet and priced right!
http://forums.maxima.org/showthread.php?threadid=88114
Old Jan 3, 2002 | 12:44 PM
DenMax's Avatar
Shameless plug
I like I like!!
Colonel's Avatar
Old Fuddy Duddy
what do u recomend
You really have to have a good filting system on the intake somehow to protect your motor.
I have another thread comparing the two top aftermarket filter systems PRCAI(cattman) and Stillen(and others of similiar design). Seems like it really comes down to $$$ and personal preference though. Dynos and 1/4 miles seem to contradict. Dyno for SI is higher, but 1/4 for CAI is quicker. There is another link in that thread as well to check out. There is more tech info than needs to be repeated here.
In THEORY, running an open MAF/TB would be good if you had NO particles to suck into your motor. Mesh aint gonna cut it. Stick with something proven, you'll save yourself headaches in the long run.
Old Jan 3, 2002 | 12:52 PM
BigDogJonx's Avatar
The only think you need is remove the stock airbox, and take the MAF sensor and then hookup a K&N style cone filter. Costs about $25 at Autozone.
Only problem is the one side of the MAF sensor has a SQAURE opening, you need to have a plate made to attach it with 4 screws and have the plate also have a 3" pipe fitting on it. This is what Stillen and JWT Popchargers basically are, i mean obviously it is different, but the way the MAF side connectes to the Cone filter is the same,
Dixit
Old Jan 3, 2002 | 12:54 PM
irvine78's Avatar
i think...you need surface area>>the bigger the surface area, more air..filter has to be there, cuz even with a single grain of dirt, that can ruin your injectors..
Old Jan 3, 2002 | 02:15 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Iwubu
Bluenissan
Sep 20, 2015 08:54 PM
cruce91
Sep 20, 2015 10:23 AM
pears
Sep 18, 2015 05:25 AM
Mahmuth
Sep 17, 2015 11:45 AM
Maxboy23
Sep 9, 2015 10:37 AM
