5.5 Gen is running rich
Old Mar 21, 2012 | 01:18 PM
HDB Audio's Avatar
Hi guys,
since last year my 03 Maxima is running rich as hell. I have an EVAP CEL. My car is smelling gas a lot from the exhaust. I have Cattman headers, y pipe ... NWP spacers, i already cleaned my TB, new spark plug, CAI... I need help to solve this ! thx
Old Mar 21, 2012 | 07:32 PM
You need a tune.
Old Mar 22, 2012 | 12:22 PM
NmexMAX's Avatar
dot dot dot ...
Fix the SES. Check for more SES. My car smells like gas sometimes and it's not running rich.
Old Mar 22, 2012 | 01:40 PM
Grand_hustle17's Avatar
dyno or buy a wideband to be certain... bad injectors can cause the "gas" smell
Old Mar 22, 2012 | 03:28 PM
Rods03Max619's Avatar
Post1
Post2 or
Post3
ALL OF THE ABOVE.....
Old Mar 22, 2012 | 05:21 PM
Amave's Avatar
rich condition can be cause by A) too much air in the system and the ECU is trying to compensate by dumping fuel or B) your oxygen sensor(s) are or have taken a dump and are not sending correct voltage signal to the ECU.
The ECU uses the inputs from your upstream oxygen sensor to determine pulse width in your injectors, if it sees an incorrect voltage signal it will leave the injectors open longer thus adding more fuel .
The ECU has no idea if the oxygen sensors are bad ( other than a CEL when it sees an incorrect signal ) it will take the info it gets from the oxygen sensor and either add or remove fuel.
It would be cool if the ECU knew the sensors were bad and then ignore them, but it doesn't .
Old Mar 22, 2012 | 05:32 PM
luvlexus101's Avatar
tune ittttttttt!
Old Mar 23, 2012 | 07:20 AM
HDB Audio's Avatar
Allright ! Thx guyz ! I scanned the Max again and found a O2 sensor code ! So I'll get a O2 dual sim and things should be OK ! I also really want to tune it and advance timing but from what I read, it's pretty expensive .... I'll need a GReddy, wideband ....
Old Mar 23, 2012 | 07:26 AM
NmexMAX's Avatar
dot dot dot ...
Which O2 sensor was it?
Old Mar 23, 2012 | 07:31 AM
HDB Audio's Avatar
Rear O2 sensor
Old Mar 23, 2012 | 08:11 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by HDB Audio
Rear O2 sensor
Then that's probably not your problem. Front O2's control closed loop (MAF does the open loop), rears are back-ups to the fronts (in case the fronts go out of their range, the rears take over as primaries) and also the secondaries are said to monitor precat function.
Old Mar 23, 2012 | 08:19 AM
HDB Audio's Avatar
Ok !! Thx a lot ! But I still not have any solution ! :P exept for a complete tune with e-manage !
Old Mar 23, 2012 | 08:20 AM
02whitemaximase's Avatar
Get the spark plug antifouler first, cheap fix ($5) and they are locally available at any auto parts store.
Old Mar 23, 2012 | 09:21 AM
NmexMAX's Avatar
dot dot dot ...
First things first, verify you're running rich, quantitatively, not qualitatively. So do what Hustle said.
Old Mar 23, 2012 | 10:51 AM
Yeah I got the full Cattman and I was only smelling it dumping fuel on the freeway when I would get up on it after install but now nothing, I need to get up on a dyno also...soon very soon...
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MikesChevelle
Aug 19, 2015 07:19 AM
MaxStock
Aug 12, 2015 08:33 AM
