I need some Spoon feeding here...
Evening folks, So I need some spoon feeding here. I have been searching but all the answers i have found haven't really addressed my concerns. To start off, I LOVE my 00 Maxima SE. I HATE the 4sp auto it has. Absolutely depise the trans as a whole. I'm really interested in doing a 5sp swap. Before i go any further, I AM NOT capable of doing the swap myself, and would take it to a shop to have that done. Now what i'm looking for the spoon feeding is were would i find all the necessary parts? Also, What would said parts cost? And finally what would i be looking at cost wise for a shop do do all the work? Thanks guys (and gals)
EDIT: I should say, I don't want to sell my car and buy a car with a 5sp. I know it would be theoretically easier, But i know how well i have taken care of my car. It's very low miles etc. On top of that finding a reasonably priced SE 5sp with low miles here that appears to of been taken care of is mindbogglingly difficult.
low mileage SE 5psd looks pretty clean here http://forums.maxima.org/maximas-sal...t-se-sale.html
either way its low mileage for a 11 year old car(mileage for that car should be at 132K based on 12K per year).But, there are plenty of threads about a 5spd swap so just take some time and search, a few of those threads even list the parts needed. good luck
http://www.dynomagic.com/5spd_conversion.htm
That is a link for 5 speed swap on a 4th gen. I'm pretty sure the parts and things needed wouldn't be much different.
As someone recomended, I talked to aacshun and he's a MAJOR help with this. The parts list he made up for me is;
MT Flywheel
MT Flywheel Bolts
MT Flywheel spacer thingy (goes in between the flywheel and the crank)
240mm 24 spline Clutch Disc
Pressure Plate
5MT Transmission Assembly
Shift Rod Linkage and Shifter Assembly
5mt Shifter Trim
Wire in the PNP Switch
Wire in the Reverse lights
Swap to a MT ECU
Clutch Assembly
Throw out bearing
5 quarts Synthetic Manual tranny fluid
What does everyone think these will cost me? I'm assuming used is the only way to acquire them.
MT Flywheel
MT Flywheel Bolts
Pressure Plate
5mt Shifter Trim
Swap to a MT ECU
Clutch Assembly
Throw out bearing
MT Flywheel
MT Flywheel Bolts
Pressure Plate
5mt Shifter Trim
Swap to a MT ECU
MT Flywheel
MT Flywheel Bolts
Pressure Plate
5mt Shifter Trim
Swap to a MT ECU
homewrecker
Aug 24, 2015 08:56 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
, And is there anything on that list that would be suggested buying new? Not everything, but certain items that perhaps aren't commonly found in good condition used?
