NEED HELP TESTING COILS WITH DIGITAL MULTIMETER ASAP
Old Apr 5, 2012 | 05:43 PM
yabod4lyf3's Avatar
OK I AM TRYING TO TEST MY COILS ON MY 2002 MAXIMA. I HAVE A DIGITAL MULTIMETER. I JUST NEED TO KNOW WHAT TO SET IT TO ON OHMS AND WHAT NUMBERS AM I LOOKING FOR TO SEE WHATS GOOD AND WHATS BAD. I DO NOT HAVE ANY MANUALS FOR MY CAR SINCE THE PERSON I BOUGHT MY CAR FROM THREW THEM AWAY. PLEASE ANY HELP WOULD BE GREATLY APPRECIATED. PLEASE EXPLAIN ANY STEPS OR ANYTHING IM TRYING TO GET THIS DONE AND REPLACE ANY THAT ARE BAD SINCE I CANT REPLACE ALL OF THEM AT THIS TIME.
Old Apr 5, 2012 | 05:51 PM
Amerikaner83's Avatar
if you set the meter for auto range you're good.
http://forums.maxima.org/4th-generat...ultimeter.html
^^ pay attention to post number 2. Found that thread with a 10 second google search with terms "maxima coil testing with multimeter"
also under the same google search...
http://www.ehow.com/how_5982574_test-nissan-coils.html
Old Apr 5, 2012 | 06:00 PM
ShocknAwe's Avatar
I think he meant what setting as opposed to how to physically test them. YOu will use the Ohm setting which looks like an upside down horseshoe. Start out on the lowest setting and if you get a 1 then move to the next and so on until you get a valid reading. In reality, the best way to test coils is to simply remove the clips and see if the engine idle changes. Once removed if the engine starts to idle rough, then the coil is good. If nothing changes then obviously the coil is bad because it is not doing anything. GL on the rear coils lol
Old Apr 6, 2012 | 07:45 AM
DennisMik's Avatar
Set your meter to measure ohms. Depending on how your meter is made, use the megaohm scale or the autorange scale.
Unplug the wire from the coil pack and measure between the pins on the coilpack.
There are 3 connections:
Pin 1 different color on each coil pack
Pin 2 black wire on every coil pack
Pin 3 red wire on every coil pack
measuring between Pin 3 and Pin 2 connections:
positive lead on Pin 3 reads open (or infinity)
positive lead on Pin 2 reads 7.7 megaohms
measuring between the Pin 2 and Pin 1 connections:
reads 1.5 kilohms (polarity doesn't matter).
measuring between Pin 3 and Pin 1 connections:
positive lead on Pin 1 reads 7.7 megaohms
Old Apr 6, 2012 | 07:50 AM
foodmanry's Avatar
Da Roller Coaster!
In reality, NO because the removed coil does not always act up. The remove a coil and no change really only works for a coil that is bad all the time.
I had two bad coils when using the test method, but I didn't feel it all of the time.
Old Apr 6, 2012 | 07:57 AM
foodmanry's Avatar
Da Roller Coaster!
To the OP...please see image below.
Old Apr 6, 2012 | 11:12 AM
cabernet's Avatar
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
