Front bearing replacement (2000)
Old Apr 16, 2012 | 09:30 AM
pkrainert's Avatar
Hey guys,
So my wife's car needs new front bearings it sounds like a spaceship or something with all the humming. I have replaced the rears before but I just bought a hub/bearing assembly so it was really easy.
Is there something of the sort available for the front? I have access to a press so I don't mind pressing a new bearing into the old hub BUT I am fairly certain the hub is going to be shot... As far as I know they are the original bearings (135k miles).
Old Apr 16, 2012 | 09:59 AM
VQP0WER's Avatar
Will definetly need a press to get them out and in. As far as the hub being damaged, you won't know till you take that bearing out. It's not a complicated job. I remember doing mine a few years back when I had the Maxima.
Old Apr 16, 2012 | 10:47 AM
Shift_Max's Avatar
Honestly I would just buy a brand new wheel bearing and a hub. Spend the extra money now instead of having to wait to find out that you will need a new hub when you remove the old bearing.
Plus it will be a simpler job to replace both items at once. But you will need to press the hub and bearing out of a knuckle and that requires removal of the knuckle assembly from the car.
Old Apr 16, 2012 | 10:48 AM
pkrainert's Avatar
Well I have a press so its not an issue, I just don't want to get it all apart and realize I need a hub and be stuck without a car lol. Maybe I will err on the side of caution and just order a new hub while I am at it.
Has anyone used the Timken bearings? I am leaning towards OEM but they are $$$
Old Apr 16, 2012 | 10:51 AM
Shift_Max's Avatar
Yeah I had that happen actually. I only bought a bearing and took it apart to realize that the hub had wear on it. Then i had to wait a couple of days before the hub arrived. Get both and install them IMO.
I had used OEM hub and bearing so I have no experience with aftermarket units.
Old Apr 16, 2012 | 10:56 AM
pkrainert's Avatar
Do you recall the cost for the OEM hub and bearing?
Old Apr 16, 2012 | 10:59 AM
L_U_D_I_AMaxima's Avatar
wow I just checked Courtesy Nissan... looks like the price for the hub and bearing is just over $200 per side... pretty pricey
Old Apr 16, 2012 | 11:07 AM
pkrainert's Avatar
I know I am not looking to spend 400 dollars just to do bearings on this car lol I am already fed up with it.
Old Apr 16, 2012 | 11:47 AM
http://www.youtube.com/watch?v=1qw7Mk41q5k
may be we can get a mod to make this a sticky or something... I know it says 04 but the procedure is the same
I guess it depends on how easily you take the hub out you might me OK with just replacing the bearing pkrainert
Old Apr 16, 2012 | 11:55 AM
pkrainert's Avatar
I watched that video last night lol. I have a press so I won't risk damaging the bearing with that method but its good info for those without access to a press. My local machine shop is pretty cool with pressing stuff for a small fee so that may also be an option for the DIYer without a press.
HOKUSMAX
Nov 13, 2017 04:34 AM
homeyclaus
Sep 3, 2015 06:15 PM
jholley
Aug 11, 2015 09:38 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
