Juke rims on a '02 Maxima SE?
Old May 1, 2012 | 09:25 AM
CiViCKiDD's Avatar
I found a new set of Juke rims/wheels for sale locally, but they have a higher offset (47mm) than our OEM Maxima rims (45mm I believe). They're both 17x7 wheels.
Any reasons not to pick these up (fitment issues)?
Old May 1, 2012 | 09:27 AM
phatboislim's Avatar
Old May 1, 2012 | 09:29 AM
NmexMAX's Avatar
dot dot dot ...
In my years of owning both an A32 and A33 Maxima, I would never go below 8" wide nor above 30mm offset.
They should fit, 2mm is darn near nothing, the only item to watch for is tire rubbing in the strut housing.
Old May 1, 2012 | 09:54 AM
It should be fine as I told you. I don't think 2mm is enough of a difference to affect anything in any sort of way.
Old May 1, 2012 | 11:40 AM
CiViCKiDD's Avatar
Excellent, I had to double check - thanks guys. I'll see if I can pick the wheels up this week..
Old May 1, 2012 | 12:43 PM
nismopc's Avatar
OEM Max rims already sit too far in. Are the JUKE's a wider rim?
If not, they will look worse than OEM rim fitment already does.
EDIT: I looked this up and found the following on JUKE rims
Standard 17"
Bolt pattern: 5x4.5" (5x114.3mm)
Offset: +45mm
Sport 17"
Offset: +47mm
Old May 2, 2012 | 08:37 AM
Rods03Max619's Avatar
Good Luck on them, abd be sure to post some pics....
Old May 2, 2012 | 08:39 AM
luvlexus101's Avatar
nooooooooooo
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
criminalslang810
Aug 16, 2015 08:12 AM
RealityCheck
Aug 5, 2015 06:18 AM
