Throttle Lag
Old May 2, 2012 | 06:53 AM
miri88's Avatar
Throttle Lag
hey can anyone tell me wha the problem might be when I punch the gas full throttle, it happens to lag like it doesn't take off right away it like studders when u punch it...
2000 Maxima GLE
120,000 miles
automatic
Old May 2, 2012 | 06:57 AM
UGAd13's Avatar
Two words... Sprint Booster (that'd be funny if it worked on the 5th gen)
It's a 2000 with 120k miles on it. Have you done any maint? Start there - TB, MAF, etc. Check cables.
Old May 2, 2012 | 07:03 AM
miri88's Avatar
man I wish I knew wha u meant by those, I'm not an expert lol, only maintenance I've done was oil to tell u the truth... from the previous owner... I think spark plugs, motor mounts, some idle thing that car would shut off when u turn it
on... not really sure, what is usually the problem for lagging? can it be transmission? I mean some times when I'm driving it's not smooth changing gears also like from 1 to 2 it's a lil hard shift
Old May 2, 2012 | 07:16 AM
2brosgixxer's Avatar
Is your Check engine light on? TB=throttle body, MAF=mass air flow sensor. Clean them both. Check air filter. Are your plugs NGK? If not, get NGK and put them in.
Old May 2, 2012 | 07:22 AM
miri88's Avatar
no idea wha the plugs are... I'll try to find out... check engine light is on I believe they were
P0420
P0450
MAF i don't know where it is
TB i don't know where it is unforturnely for me
Air filter is good I believe it looked fine to me
Old May 2, 2012 | 07:57 AM
miri88's Avatar
my brother tells me it's not lagging he says it's transmission slipping (he's not a mechanic) but
he knows about cars
Old May 2, 2012 | 08:04 AM
UGAd13's Avatar
Geez....
You're familiar with the internet... so do a search for the codes and what they mean. Search for everything else or just take it to a mechanic.
Just a FYI - when asking for help you need to be more specific up front.
Old May 2, 2012 | 01:10 PM
I don't want to be a d1ck, but you have been given some things to try. You will need to search if you don't know where they are located. This stuff has been covered somewhere. There are stickies in the 5th gen section that will walk you through cleaning the stuff you need to clean.
Read thru this
http://forums.maxima.org/5th-generat...t-reviews.html
And this
http://forums.maxima.org/5th-generat...n-how-diy.html
It also seems you started a thread on the 13th asking about the codes. You were given answers as to what they were but you have not fixed the 0420 code yet. Fix that, clean the things about then report back AFTER searching and be specific when you post back.
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
Bonka
Sep 14, 2015 11:18 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
