im all for trying something new but i dont think the results of that coupling will be worth the effort. Even thou you are raising the compression the 3.5 head>>>the 3.0.
What would be interesting if you are willing to drop the guap, is a 3.5 with a compression ratio in the 12.x:1, you already have the tuning equipment. we would definitely be seeing up words of 300whp.
Why the sudden change of heart?
But that's the final bottleneck IMO for your setup. Your heads have the capability of flowing so much air, but your current displacement can only pump so much. It will really wake up what you have. I'm willing to bet that you'll hit 240hp at 5k and it will just keep climbing from there.
PS I PM'd you.
Man, fck that. My heads are not stock 3.0 heads. And without a flowbench you can't say whether ported/polished/valvejobbed 3.0 heads are worse than stock VQ35 heads. Not hearing it.
Because I have a leak in my rear main seal, and I'll be goddamned if I pay hella labor to pull the oil pans to fix this POS seal without getting any satisfaction out of it.
PS I PM'd you.
PS I PM'd you.
PS I PM'd you.
PS I PM'd you.
Get your heads flowtested so there will be no guessing involved.
I know they are not stock 3.0 heads. I know you want to hold on to those heads but it would surprise me if you are just at the level of a stock 3.5 head. A 3.5 head with just valve springs could very well out flow you.
They have the head flow up there.....and Cossy heads flow well into the 400s. It seems they were taking advantage of the compression bump more than the head flow, probably because they didnt have to change much of anything in the 3.5s short block.
Put that thing on a dynojet. And unless you add EVT I don't see anything gained at peak. IVTs do the under the curve thing but have yet to add anything peak that's why they retard for optimal performance otherwise. EVTs ate where it's at for peak/ post 5K gains.
But at the same time, I'm hoping to confirm/disprove that theory when I'm done with mine.
I was busy basking in Boston kicking Miami's *** again.... But I'm on the sidelines with this one... Don't have anything to say, I just want some coilovers that's all
What kind of port and polished job, I know they offer so many different flavors when it comes to p&p, light, milded to wild. it all depends on whos doing the job and how big of a port you got... so power gain all very.... you could very well have a head that out flows the 3.5 head and the nismo heads
If one of you guys could give me the answer to these questions it would be greatly appreciated :
1: is it possible to use an se 6mt cluster in the auto without problems.
2: and were do you install the camder bolt kit at and does any body have pictures
Thats about as low as Im willing to go on struts/springs. ATL's roads are more like a lunar surface than a race track. If the XYZ's come in then it can drop some more. LOL I took half my stickers off for you guys!! All I have on there now are the AEM, NWP and Mishimoto stickers on the sides and an eat sleep Nissan on the back. They stay
this is me in atl
aackshun you know a machine shop?if you do why dont you buy a rod of solid poly and have them cut and lathe you custom fitted mounts for like $50 and you can make all your mounts the same
http://www.usplastic.com/catalog/ite...4015&catid=716
http://www.usplastic.com/catalog/ite...0546&catid=484
And be a BIG BALLER and make your exhaust out of carbon fiber pipe
http://www.rockwestcomposites.com/br...-carbon-tubing
http://money.msn.com/personal-financ...-billions.aspx
Wow, it only took 20+ years of potheads telling the gov'ment this before they realized it?
You are extremely defensive dawg, relax.
