Old Jun 9, 2012 | 05:52 AM
  #7321
essential1's Avatar
My axles cry for mercy...
And are you old ******* really having an analytical discussion on coolant?
Old Jun 9, 2012 | 05:54 AM
  #7322
BobPezz's Avatar
Originally Posted by cjandura
He has turned Commie Bob and he is using slang and next he will be trying to denounce his citizenship.he has already scorned us home protection device owners.God only knows whats next on his list.
Hmmmmm.....IIRC 'Chester' did mention he was from Ukranian ancestry!
Old Jun 9, 2012 | 05:56 AM
  #7323
cjandura's Avatar
Bob makes his own antifreeze in his meth lab its a hobby his craigslist add says Welcome to Bob's Meth & Bomb discount outlet
Old Jun 9, 2012 | 05:58 AM
  #7324
essential1's Avatar
by the way CJ, I haven't gotten a chance to swing by my parents house for those brackets yet.
  #7325
cjandura's Avatar
No were just pointing out Rochester made a mistake and must be ridiculed for it
Old Jun 9, 2012 | 05:59 AM
  #7326
cjandura's Avatar
No rush im still working the kinks out the 97 before i jump on the 03
Old Jun 9, 2012 | 06:05 AM
  #7327
cjandura's Avatar
Im thinking of pulling the k sports off the 03 and mod them to fit the 97 i know i need to weld and redrill the bottom mount but how far off is the top mount is what bothers me
Old Jun 9, 2012 | 06:06 AM
  #7328
essential1's Avatar
Dont do that, just make the hole bigger. Let me see if I can find a pic of Nax's 5th gen JIC's he modded to fit his 4th gen...
Old Jun 9, 2012 | 06:09 AM
  #7329
essential1's Avatar
Do this. Or your other option is to use the 5th gen hub...
Old Jun 9, 2012 | 06:11 AM
  #7330
BobPezz's Avatar
Actually, to be honest I've got WalMart coolant in my car. Seems identical to Prestone BTW, but way cheaper.
The radiator let go emptied the cooling system & the engine got hot. On replacing the radiator, I wasn't going to put expensive coolant back in until I knew everything was OK. Made it through winter no problem, haven't had to add a drop no telltale signs of coolant in the oil.
Old Jun 9, 2012 | 06:20 AM
  #7331
95VQ30's Avatar
Need more info on this dip.can i dip porkchops and cracklins in it?
Everyone has their own version. It's chicken, franks red hot, cream cheese, white American cheese, and ranch.
I use grilled chicken and chop it up very thoroughly. In a crock pot I add butter and milk- when it gets warm, I had cream cheese and the white American cheese. When that melts together, you add your hot sauce(I use Franks then add a small amount of BBQ sauce). Then add your chopped chicken, lastly add the ranch.
The final result should be a creamy, spicy and zesty chicken dip that is as addictive as bath salts. Eat with tortilla chips
Old Jun 9, 2012 | 06:27 AM
  #7332
essential1's Avatar
C'mon Denver... you know you want BF3! There is no reason to play COD no more.
Old Jun 9, 2012 | 06:33 AM
  #7333
cjandura's Avatar
Dont need to do anything to the top mount?
Old Jun 9, 2012 | 06:35 AM
  #7334
cjandura's Avatar
Sounds good
Old Jun 9, 2012 | 06:38 AM
  #7335
essential1's Avatar
Same **** if I remember correctly.
Old Jun 9, 2012 | 06:41 AM
  #7336
TunerMaxima3000's Avatar
I'm not old
Old Jun 9, 2012 | 06:52 AM
  #7337
essential1's Avatar
I'm not old
Infinitis are old people cars. They are the japanese lincon... Everyone who drives an infiniti is old...
Wait...
Old Jun 9, 2012 | 06:54 AM
  #7338
Clashez's Avatar
Bored at the shop..... wonder who I can reel in today. For there dose of clash lol joking. Getting aem wide band installed today just a few steps closer to that dyno tune
Old Jun 9, 2012 | 07:01 AM
  #7339
BobPezz's Avatar
Southern cops have a way with words!
Here's one too good not to share here!
http://forums.maxima.org/8504868-post229.html
Old Jun 9, 2012 | 07:04 AM
  #7340
aackshun's Avatar
The 07-08 G35 Sedans or any relatively new Nissinf we got @ work has had the blue/greenish A/F drain outta it.
Not red.
And crusher, you foo', you can use any FWD VQ alternator you want, here I am about to buy an alternator from work shamee.
Old Jun 9, 2012 | 07:07 AM
  #7341
Clashez's Avatar
What's up with this Nissan power chip ad lol
Old Jun 9, 2012 | 07:08 AM
  #7342
aackshun's Avatar
Buy it suckah.
Old Jun 9, 2012 | 07:11 AM
  #7343
cjandura's Avatar
Not red.
Red is toyota,pink is honda
Old Jun 9, 2012 | 07:13 AM
  #7344
cjandura's Avatar
I'm not old
Think again hangin with Rochester adds 15y to your age
Old Jun 9, 2012 | 07:16 AM
  #7345
cjandura's Avatar
Rebuild you alt you slacker better yet get a 14661 alt and swap the rotor and stator over to the max alt so it puts out 230amp
Old Jun 9, 2012 | 07:20 AM
  #7346
Clashez's Avatar
The GF Performance Chip utilizes the latest in technology from the automotive engine control sector. Our product allows you to take your car’s performance to the next level. Our product is designed to work with any car in any weather condition and with any combination of different engine modifications. You can have a factory turbo, aftermarket turbo, supercharger, NOS kit, and our unit still remains compatible and able to compensate for any of these variables. To understand how our Performance Chip System functions a few things must be known about electronic fuel injection systems:
The unit responsible for controlling your engines fuel, ignition, throttle position, intake temperature, along with a few other variables. This engine management unit is called the ECU (Engine Control Unit). This is the main unit that our Performance Chip interfaces with to create more power, fuel mileage, etc. The ideal air fuel ratio (mixture) is termed stoichiometric. This means that there are 14.7 parts air to 1 part gasoline. By achieving this air fuel ratio an engine is able to run more efficiently, meaning better gas mileage, better emissions and more horsepower. Through rigorous research we were able develop a system that adjusts the factory ECU's settings in order to produce this ideal fuel mixture. Ideal ignition (spark) timing can only be utilized once ideal fuel ratio has been achieved. By advancing the spark timing the piston is allowed to have a longer power stroke, and achieve a more complete burn of the gasoline vapors inside the combustion chamber. These factors are essential in creating more efficient power for a smaller amount of gasoline. Our system allows you to run more advanced spark timing with an ideal fuel ratio. Being that our system runs more advanced spark timing and a stoichiometric fuel mixture we advise that you can continue to use the same fuel that was initially recommended for your vehicle. Our claims are based on this, so there is no need to run higher octane fuel. We have found in our research that our system will indeed put out virtually the same power on lower octane fuel vs. higher octane fuel. We are proud to say we are the only chip manufacturer that can make such claims.
Due to government regulations on emissions and power, many manufacturers program your car's ECU with very modest fuel and spark settings that negatively influence your car's power and gas mileage. All of these factors together form a problem that we are now able to solve with the GForce Performance Chip. We have developed a system that is able to intercept and reconfigure the signals transmitted to the ECU. This enables us to essentially reprogram your ECU to attain maximum efficiency meaning better gas mileage and more power to the ground. The chip is able to work dynamically with the ECU meaning it will compensate for the current load your engine is under:
When you are full throttle your engine load is increased dramatically over normal freeway cruising, so the chip tells the ECU to compensate for the larger volume of incoming air by injecting more fuel into your engine and advancing the timing, giving you increased overall horsepower When you are cruising on the freeway or in the city the load on the engine and incoming air is little so the chip tells the ECU to use less fuel in order to achieve maximum fuel economy
Regardless of your driving style our chip will provide a substantial increase in performance over stock. All of these benefits are achieved without disassembling or reprogramming your ECU thereby preserving your factory warranty or permanently altering your car in any way shape or form. What sets us apart from our competition, we offer a solid product that we stand by, so much so that if you are not satisfied in any way we will offer you a 100% no questions asked refund. Our GForce Chips may sound too good to be true, but let’s say that the results speak for themselves.
Moe powwa lol
  #7347
cjandura's Avatar
This new trans shifts kind of hard maby i need to get used to it.im driving to the land of pies and cake Lancaster amish town
Old Jun 9, 2012 | 07:27 AM
  #7348
Clashez's Avatar
Buy it suckah.
What ever it takes to hit 300whp n/a.... enough edges eventually make a sword lol
Old Jun 9, 2012 | 07:40 AM
  #7349
essential1's Avatar
this.
Old Jun 9, 2012 | 07:41 AM
  #7350
cjandura's Avatar
Fact reading more then 2 post from clashtart requires you to wear a helmut and ride the special little bus to understand
Old Jun 9, 2012 | 07:50 AM
  #7351
cjandura's Avatar
this.
You could also take a 210amp GM 8103 alt with a 708 regulator in it and splice a gm harness plug to the nissan and use it the 8103 has the same mounting
Old Jun 9, 2012 | 07:57 AM
  #7352
essential1's Avatar
Has the same mounting really? I didn't know that. Good to know though.
Old Jun 9, 2012 | 08:06 AM
  #7353
cjandura's Avatar
During the early 90's manufactures kind of went with common mounting on alts it started with the gm cs130 style alt because it was getting out of hand they designed 5 different mount patterns and 2 CE housings so all you would have to do is reclock the CE to adjust the plug location and many of the others followed by using the same mounting dimentions with different clock depending on right or left side mounting
Old Jun 9, 2012 | 08:22 AM
  #7354
Clashez's Avatar
Cj my biggest fan
Old Jun 9, 2012 | 08:32 AM
  #7355
Clashez's Avatar
Cj you need to start showing me some respect, I'm going to be part of the family soon
Old Jun 9, 2012 | 08:38 AM
  #7356
cjandura's Avatar
Should i black out the grill on the 97 or get a new one?the chrome is starting to chip maby ill hit it with some plasti and see
Old Jun 9, 2012 | 08:44 AM
  #7357
Clashez's Avatar
I think you should stop lieing taking about you got 3 maxima's and a gt-r let see a picture of u and this gt-r
Old Jun 9, 2012 | 09:01 AM
  #7358
He's already shown his insurance statements
Old Jun 9, 2012 | 09:02 AM
  #7359
cjandura's Avatar
Oh pics are coming i gots phone now and lets see him man up and run me on the track now
Old Jun 9, 2012 | 09:03 AM
  #7360
cjandura's Avatar
He aint nuttin but a low life bastad anyway
