Old Jun 21, 2012 | 12:53 PM
  #11521
cjandura's Avatar
You can do like chocolatestraw and get the zx rotors cut down but thats issues
  #11522
Shift_Max's Avatar
lol
Old Jun 21, 2012 | 12:54 PM
  #11523
Grand_hustle17's Avatar
Originally Posted by cjandura
Make sure the rebuild kit has the O rings that go between the halves most kits dont and oe dont list them no more
looks good??
Old Jun 21, 2012 | 12:55 PM
  #11524
ranmas2004's Avatar
also is matts brackets the only option???
I used a front brake kit that extends the bracket back to fit the OEM caliper on with a 12.8" rim.
and on the back brakes I used FASTBRAKES rear brake kit that has bracket to move OEM caliper back and use a 12.1" rotor.
I also upgraded to SS brake lines. I think thats going to be just fine.
  #11525
or just buy slotted drilled cobra rotors off ebay for $90 lol
Old Jun 21, 2012 | 01:04 PM
  #11526
take it you meant rotor... why do i need the calipers moved to the rear??? i actually like how they look in the front more... just me.. nothing of extreme fancy... if coating the 6th gen calipers looked as good then that wouldve been the choice... i just want a pretty looking brake setup... 300zx calipers (painted in some color of my choice) and some nice rotors lol dats all nothin more fancy
Old Jun 21, 2012 | 01:10 PM
  #11527
NmexMAX's Avatar
dot dot dot ...
ramnas has stock calipers all around.
He has relocation kits for both front and rear so he can use a larger rotors WITH the stock calipers, front and rear.
Old Jun 21, 2012 | 01:11 PM
  #11528
ranmas2004's Avatar
No, perhaps I explained that wrong.
On the front brakes. I used the OEM calipers. I bought a kit that uses brackets to move the OEM calipers out more to accept a 12.8" rotor.
On the back I used the OEM rear calipers and bought a kit that uses brackets to move the OEM calipers out to accept a 12.1" rotor.
That is what Im talking about. Nothing fancy, no big Brembo brake calipers, no 300zx calipers...all OEM....just stock OEM calipers. Only thing I did was buy all new calipers for the front and rear since the car had 115k miles on it.
Old Jun 21, 2012 | 01:13 PM
  #11529
cjandura's Avatar
looks good??
Your looking for 4 8mm OD O rings
  #11530
That is what Im talking about. Nothing fancy, no big Brembo brakes....just stock OEM calipers. Only thing I did was buy all new calipers for the front and rear since the car had 115k miles on it.
gotcha gotcha, i was thinking you moved the calipers from the front to the rear like how it looks on a 911 lol...
Old Jun 21, 2012 | 01:14 PM
  #11531
http://www.z1motorsports.com/product...roducts_id=715
Old Jun 21, 2012 | 01:16 PM
  #11532
cjandura's Avatar
http://www.nicoclub.com/archives/reb...-calipers.html
  #11533
Rochester's Avatar
I've been only skimming through this thread today, and just now noticed this.
If you put them side-by-side, it looks like he has a poached egg on his shoulders.
Old Jun 21, 2012 | 01:17 PM
  #11534
cjandura's Avatar
I miss that old 300 i had it was ugly forest green tan leather and digital dash
Old Jun 21, 2012 | 01:23 PM
  #11535
ranmas2004's Avatar
u crazy...lol.
Old Jun 21, 2012 | 01:26 PM
  #11536
cjandura's Avatar
Old Jun 21, 2012 | 01:31 PM
  #11537
Rochester's Avatar
u crazy...lol.
But it's right in front of you, ranmasaman! Your avatar is wearing his breakfast!
How could you not see that, man?
Old Jun 21, 2012 | 01:39 PM
  #11538
essential1's Avatar
My axles cry for mercy...
you can ask for pictures of t on a scale. HArd to lie about the heavy *** iron cal's. Either way though the iron ZX cal's are still better and its not like they are dumptruck heavy
Not dump truck heavy? Wtf you smokin? Lol. I went from iron to aluminum and they way heavier. It felt like I through a set of light weight wheels on when I changed.
lmao... i dont care about the weight lmao... as long as they work im good... i want it for the looks
whats the weight difference?
Huge weight difference. Calipers felt heavier than when I changed the brakes on my cousins navigator.
  #11539
Old Jun 21, 2012 | 01:45 PM
  #11540
cjandura's Avatar
you see that rebuild link for the calipers
Old Jun 21, 2012 | 01:46 PM
  #11541
dumptruck heavy though... cmon man lol...
o.k another question, CJ said should stick to the 95-96 calipers... my question, are all the models of the 300zx 95-96 calipers the BBK caliper upgrade for maximas???... the reason im asking is #1 i dont know anything of those cars, i actually cant even stand the look of them (but thats another topic) i just simply want to know if the 95-96 turbo or non turbo 300zx the "lighter" calipers that i should get... the calipers i found was from the 96... im not sure if the calipers are different from *whatever year they start-94 and then lighter in 95-96 or is it a case where the heavier brakes is on the non turbo and lighter on the turbo car or vice versa??? yall nikkaz confusing the noob lol
Old Jun 21, 2012 | 01:47 PM
  #11542
Rochester's Avatar
That's true, you do amuse me, cj. More so today than usual.
Old Jun 21, 2012 | 01:49 PM
  #11543
yea ill just buy the rebuild kit anf pay the powder coating shop to change em out... here is my 1 question if i do decide to do it myself thats kinda confusing to me in the link..... what did he use n how did he remove the piston, i think im a tad thrown off there lol
Old Jun 21, 2012 | 01:52 PM
  #11544
cjandura's Avatar
all you need to ask for is the alum 1996 300zx tt calipers
Old Jun 21, 2012 | 01:53 PM
  #11545
phatboislim's Avatar
Old Jun 21, 2012 | 01:56 PM
  #11546
cjandura's Avatar
Front Calipers:
(Numbers listed as RH caliper / LH caliper respectively)
41001-30P00 / 41011-30P00 Manufacture date 2/89 – 7/90 (N/A Aluminum 26mm)
41001-40P00 / 41011-40P00 Manufacture date 7/89 – 7/90 (Twin Turbo Aluminum 30mm)
41001-40P00 / 41011-40P00 Manufacture date 7/90 – 9/91 (TT and N/A Aluminum 30mm)
41001-45P00 / 41011-45P00 Manufacture date 9/91 – 4/92 (TT and N/A Aluminum 30mm)
41001-37P00 / 41011-37P00 Manufacture date 4/92 – 8/92 (N/A Cast Iron 30mm)
41001-37P00 / 41011-37P00 Manufacture date 7/92 – 9/93 (TT Cast Iron 30mm)
41001-37P00 / 41011-37P00 Manufacture date 8/92 – 9/93 (N/A Cast Iron 30mm)
41001-37P01 / 41011-37P01 Manufacture date 9/93 + (TT and N/A Cast Iron 30mm)
Brake Hardware Kit:
41080-40P25 Twin Turbo or N/A calipers manufacture 2/89 – 8/89
41080-40P26 Twin Turbo or N/A calipers manufacture 8/89 – 2/91
41080-40P27 Twin Turbo or N/A calipers manufacture 2/91 +
Spring Return:
41090-50P01 N/A calipers manufacture 2/89 – 7/90
41090-40P01 Twin Turbo calipers manufacture 7/89 + (Alternate pt. 41090-40P02)
41090-40P01 N/A calipers manufacture 7/90 + (Alternate pt. 41090-40P02)
Old Jun 21, 2012 | 01:57 PM
  #11547
cjandura's Avatar
Old Jun 21, 2012 | 01:59 PM
  #11548
cjandura's Avatar
The following is a comparison of some different Z32 300ZX brake calipers.
The "26mm Aluminum" calipers were used ONLY on 1990 non-turbos. They used a 280mm x 26mm rotor.
The "30mm Aluminum" calipers were used on 1990 Twin-turbos and ALL 1991-1992.5 300ZX's (both turbo and non-turbo alike). They used a 280mm x 30mm rotor.
The "30mm Iron" calipers were used on ALL 1992.5-1996 300ZX's (both turbo and non-turbo alike). They also used the 280mm x 30mm rotor
this last one was revised and upgraded to the alum caliper due to consolidation of part numbers
http://importnut.net/300zxbrakeswap.htm
Old Jun 21, 2012 | 02:05 PM
  #11549
how will they know??? if its a junkyard i assume they just pull em off TT or non TT and just list em as 300zx brakes lol
Old Jun 21, 2012 | 02:06 PM
  #11550
Front Calipers:
Brake Hardware Kit:
Spring Return:
perfect ill save this
Old Jun 21, 2012 | 02:08 PM
  #11551
cjandura's Avatar
if a magnet stick its steel if not its alum also ask if it says sumitomo on the front above nissan
Old Jun 21, 2012 | 02:15 PM
  #11552
cjandura's Avatar
300ZX PARTS CAR (CHARLOTTE HALL)
1990 -1996 nissan 300zx parts (brunswick md)
  #11553
aackshun's Avatar
@ sales today....
at this rate I may even buy those 3.5 heads from moncef, someone buy a motor so I can call in sick on friday and start wiring up the red car
  #11554
i guess to avoid the aluminum one is to just get a 95-96 300zx caliper.... that couldve been said a tad easier, but the chart does help
Old Jun 21, 2012 | 02:19 PM
  #11555
Rochester's Avatar
Don't let this go to your head... but that's brilliant.
Is that your image/info, or did you find it somewhere?
Old Jun 21, 2012 | 02:20 PM
  #11556
cjandura's Avatar
Originally Posted by aackshun
@ sales today....
i'll take 4 and throw in a front half of a '12 g37
Old Jun 21, 2012 | 02:21 PM
  #11557
cjandura's Avatar
alot of research and found this out there. i have been stock piling for awhile
Old Jun 21, 2012 | 02:23 PM
  #11558
cjandura's Avatar
in reality as long as its the alum one and says NISSAN on it you will be ok there is only a 4mm piston difference and the 30mm uses a SS piston and the 26mm uses a castiron piston there is also a 6lb difference between the alum and castiron one where the difference between the 2 alum ones is only 12oz
Old Jun 21, 2012 | 02:25 PM
  #11559
TunerMaxima3000's Avatar
but what if you sent him money with manufacturing defects would he like that?
Couldn't believe this guy. He offered $20 back. I
I paid $175 plus $50 brokerage (expected)
Thats a crapload of money for a couple pieces of aluminum. And then tell me that 'so what' they're all scratched to hell? That's "normal"? No... Come on man.
If this moron doesn't make a reasonable reimbursement I'll deny his money and make it my daily job to slander his products all over the forum.
Old Jun 21, 2012 | 02:27 PM
  #11560
