Old Jul 6, 2012 | 11:34 PM
  #15161
Amerikaner83's Avatar
meh, not really.
Better not enough than "oh **** I fcuked it up" too much, I suppose I DO have a big-azz rotary buffer if I need to use it...
Old Jul 7, 2012 | 06:23 AM
  #15162
aackshun's Avatar
My launch at the track was so bad *** I had to bog it
My speedo is way the fck off, has always been in this car, that is 102mph foh shoo
Old Jul 7, 2012 | 07:01 AM
  #15163
Grand_hustle17's Avatar
Originally Posted by aackshun
http://www.youtube.com/watch?v=ePkqpQ4c8-A
U trapped 102mph?
Old Jul 7, 2012 | 07:02 AM
  #15164
Rochester's Avatar
Your car already has to be pretty immaculate for it to really do anything. If the car is old or whatever (like ours are), you're better off investing in a proper buffing.
True. Clay only removes little microscopic crap that embeds in the clear-coat, giving you that pristine, glass-to-the-touch surface. It will do nothing for faded paint, or swirls or scratches. That's not what it's for.
All that said, I bet you Amerikaner83 is still going to love the results. To wash, dry, clay, wash, dry, wax and polish... that's a full 8 hour day right there.
Old Jul 7, 2012 | 07:31 AM
  #15165
cjandura's Avatar
Yo i had to whip out the calender and abacus to calculate that 0-60 time ijs get your weight up brudda
Old Jul 7, 2012 | 07:34 AM
  #15166
Old Jul 7, 2012 | 07:37 AM
  #15167
Rochester's Avatar
Rochester, cjandura+, Grand_hustle17+, spock+
Spock? You troll.
Old Jul 7, 2012 | 07:39 AM
  #15168
cjandura's Avatar
I bet if he was hungry and makin a burger run that bish would be running red line all da way to da bobs big burger
Old Jul 7, 2012 | 07:43 AM
  #15169
cjandura's Avatar
Fish, Wop+, Rasta+, Troll+
Spock? You troll.
Fixed
Old Jul 7, 2012 | 07:52 AM
  #15170
Fixed
Old Jul 7, 2012 | 07:53 AM
  #15171
BobPezz's Avatar
I saw this solo ALMS-LMP2 Morgan-Nissan entry at Lime Rock. At least there was a Nissan on the grid.
Prototype LMP2 Morgan-Nissan. (Photo: Conquest Racing)
Did a little research & came up w/this info on the Nissan engine in it. I highlighted a few interesting points of interest.
Nissan VK engine
Manufacturer: Nissan Motor Co., Ltd.
Production: 2002–
The VK engine (formerly known as the ZH) is a V8 piston engine from Nissan. It is an aluminum DOHC 4-valve design.
The VK engine was originally based on Nissan's VQ V6 rather than the VH V8 used in previous Q45/Cima models. Changes include: a variable polymer intake manifold, newly designed heads, and a larger drive by wire throttle chamber. The intake manifold directs air through different paths at different engine speeds to boost low-end torque or unleash high-end horsepower.
The 4.5 L (4494 cc) VK45DE was introduced in 2002 and is built in Yokohama, Japan. Bore is 93 mm (3.7 in) and stroke is 82.7 mm (3.26 in). Output is 340 hp (254 kW) at 6400 rpm with 333 lb·ft (451 Nm) of torque at 4000 rpm. Redline is at 6600 rpm. It has an aluminum engine block and aluminum DOHC cylinder heads. It uses SFI, has 4 valves per cylinder with VVT and features forged steel connecting rods, 4 one-piece cast camshafts, and an unusual variable-flow induction system optimizes airflow for low- and high-speed operation and low-friction molybdenum-coated pistons and microfinished crankshaft.
Motorsport
A flat-plane crankshaft version of the VK45DE is used by Nismo for Super GT races with the Nissan GT-R instead of using the GT-R's VR38DETT twin-turbo V6 engine. The VK45DE was previously used in Nissan's 350Z Super GT car, replacing the previous VQ30DETT used in that car in 2007. In race trim, the Super GT VK45DE produces 500 PS (490 hp) and 52 kg·m (510 N·m; 380 lb·ft) of torque. Without such restrictions, the engine is reputedly capable of producing nearly 800 PS (790 hp). Nismo reasons that by using the engine, they eliminate turbo-lag, save weight and generally prefer the torque curve of the atmospheric V8.
This engine is used in the following vehicles:
2002–2006 Infiniti Q45, 340 hp (250 kW)
2003–2008 Infiniti FX45, 315 hp (235 kW) and 329 lbf·ft (446 N·m)
2003–2004 Infiniti M45, 340 hp (250 kW) and 333 lbf·ft (451 N·m)
2006–2010 Infiniti M45, 325 hp (242 kW) and 340 lbf·ft (460 N·m)
2004–2010 Nissan Fuga 450 GT, 333 hp (248 kW) and 340 lbf·ft (460 N·m)
2003–2010 Nissan President 280 bhp (280 PS) and 333 lbf·ft (451 N·m)
2007 Super GT Nissan 350Z, 490 hp (370 kW) and 380 lbf·ft (520 N·m)
2008 Super GT Nissan GT-R, 490 hp (370 kW) and 380 lbf·ft (520 N·m)
2011-2012 Various LMP2 racing cars 450 hp (340 kW) 430 lbf·ft (580 N·m)
Old Jul 7, 2012 | 07:56 AM
  #15172
@myself.... Went n got the solder gun yesterday n totally forgot the heat shrink.... Welp, this mission will be a mission for another day..... I'm lazy n ain't leaving this house...... Well not right now at least ....... ****!
Old Jul 7, 2012 | 08:00 AM
  #15173
cjandura's Avatar
Its 105 outside no need to be outside
Old Jul 7, 2012 | 08:05 AM
  #15174
cjandura's Avatar
I am looking at this fine a$$ i35 down the stree for sale 3200 silver ,black leather,optioned out and 75k on it man i think my wife is gonna kill me.that i35 some fat varristones and the iconics body kit and the cattman full exhaust and the xyz coils slammmed down like i got 6 fat jawns in da car makin a KFC run DAMN!!!!!
Old Jul 7, 2012 | 08:06 AM
  #15175
BobPezz's Avatar
Spock? You troll.
Spock? You troll.
Fixed
Apparently I'm persona non grata.
Old Jul 7, 2012 | 08:07 AM
  #15176
Rochester's Avatar
Fixed
Old Jul 7, 2012 | 08:09 AM
  #15177
cjandura's Avatar
Well we refer to you as Bob 'fat fingers' Gigliardi
Old Jul 7, 2012 | 08:10 AM
  #15178
Rochester's Avatar
Found the FSM for my car today, and I'm figuring out how to remove the fogs. Here's what I've got... nothing is easy on this car.
Remove the lower corner engine cover from under the car: 5 bolts
Remove the bumper grille (the rectangular, cross-hatched piece): 5 clips
Remove the bumper finisher (the chrome trim): 4 clips
Disconnect the fog light harness connector wire.
Remove the fog light mounting bolt.
Pull the fog light assembly forward.
Old Jul 7, 2012 | 08:21 AM
  #15179
nelledge's Avatar
"I'm just sayin'..."
Give the following instructions to your mechanic:
Fixed.
  #15180
Didn't u want a 6mt?..... Leave it alone lol
Old Jul 7, 2012 | 08:22 AM
  #15181
BobPezz's Avatar
'fat fingers' true enough. slow fingers even more. 'Gigliardi'???
Old Jul 7, 2012 | 08:24 AM
  #15182
About to go grocery shopping
Old Jul 7, 2012 | 08:34 AM
  #15183
Court date came to my house... "intent to defend" my insurance lapse fee on my 5.5 back when my car was sitting waiting to be swapped... Told em I had a letter to prove the car wasn't being driven but they refused it in hopes to $$$ in.... Now I don't have that letter
Old Jul 7, 2012 | 08:36 AM
  #15184
cjandura's Avatar
Dont try to change the headlight bulbs either like mine it takes 8 hours of panel removal pulling the front wheel off removing the splash guard FFS
Old Jul 7, 2012 | 08:38 AM
  #15185
cjandura's Avatar
Make new one
Old Jul 7, 2012 | 08:40 AM
  #15186
cjandura's Avatar
Dont get nothing thats frozen it will be cooked and or melted before you get home
  #15187
Rochester's Avatar
Originally Posted by nelledge
Fixed.
Nah, cowboy. Nothing greasy, and no special skills or tools required.
True that. The headlight assembly is a total b1tch to access. It's a frustrating design, and I think wholly intentional to make you bring the car to the dealership because your 15-cent parking light is blown.
Old Jul 7, 2012 | 08:46 AM
  #15188
Make new one
Has to have the shop header n Mech signature on it
Old Jul 7, 2012 | 08:48 AM
  #15189
$1200... I'm not paying it neither cause I wasn't wrong..... I tried to do it the way the asked n they refused... I'd rather do the jail time...
Old Jul 7, 2012 | 09:10 AM
  #15190
HA! Found the chick in tennis i was talking about.....
ill just copy and paste her name lmao
"Agnieszka Radwanska"
Old Jul 7, 2012 | 09:13 AM
  #15191
actually... thats not her but she can get it too lol... the chick i was talking about is German lol... yeeea idk the bish name lol
Old Jul 7, 2012 | 09:35 AM
  #15192
I thought it got out the bug guts/road sap/specs as well....?
HIGHLY likely When I run my hand over the paint right now after a wash, it's still brittle and catches...
Welp, I'm off. Wish me luck
Old Jul 7, 2012 | 09:45 AM
  #15193
Rochester's Avatar
Well, yes. But that's what Bug & Tar Remover is for. If you rely on the clay to remove that stuff, then you're going to use up that expensive claybar real quick. Besides, once the car is clayed and waxed properly, bugs and tar should just easily wash off.
Old Jul 7, 2012 | 10:00 AM
  #15194
cjandura's Avatar
You can get 1lb can of meguires clay at pepboys and scan the damn square barcode so they send the coupons to your phone.......wait i forgot.........jitterbug phone dont do that.
Old Jul 7, 2012 | 10:44 AM
  #15195
Rochester's Avatar
Pain. In. The. ***. So many clips...
Old Jul 7, 2012 | 10:48 AM
  #15196
cjandura's Avatar
Should of seen when i put led's in i had like 10 dixie cups labeled with clips an twisty things in them
Old Jul 7, 2012 | 10:51 AM
  #15197
cjandura's Avatar
Hustle you know any yard girls that do linen i need a few sets for summer.
Old Jul 7, 2012 | 10:53 AM
  #15198
Old Jul 7, 2012 | 10:55 AM
  #15199
cjandura's Avatar
Rochester invest in a set of plastic panel tools your gonna need them harbor fraight or eastwood is better
Old Jul 7, 2012 | 11:00 AM
  #15200
sow it???
