strut bar??
Old May 18, 2012 | 09:51 PM
Dexterity's Avatar
strut bar??
Hello. I am wondering if strut bars are worth getting.
Also I am wondering how much does a strut bar cost?
I am noob at this stuff please give some advice
Old May 18, 2012 | 09:54 PM
Rods03Max619's Avatar
Its an alright little mod, not nothing super major....there is ebay or Racingline or Stillen and maybe a couple others.....
Old May 18, 2012 | 09:56 PM
UncleSmitty's Avatar
I feel that a good quality strut bar is worth getting. Alot of people will say a strut bar does s*** for handling, but then again one would question the product. I myself have a good experience with my quality strut bar.. try http://racinglineperformance.com/sho...&idcategory=12 Nothing but good reviews..
Old May 18, 2012 | 10:01 PM
Amerikaner83's Avatar
Bought mine on ebay...I DID notice a difference up front. Added a RSB a week or so afterward, thing is just PLANTED in turns, no body roll. Love both of 'em!
Old May 18, 2012 | 10:03 PM
Got the same one powdercoated it Black.....
Old May 18, 2012 | 10:04 PM
ShocknAwe's Avatar
http://www.nextgentuning.com/Ultra_R...duct--234.html
Def not the best price but that bar or racingline or dont bother
Old May 18, 2012 | 10:09 PM
RSB? rear strut or sway bar?
UR is a serious company..
Last edited by UncleSmitty; May 18, 2012 at 10:12 PM. Reason: Just saw second post
Old May 18, 2012 | 10:11 PM
ShocknAwe's Avatar
THey make damn good strut bars thats for sure. Strut bars DO serve a purpose but for the avg driver they do not. If you do not track your car and need all the help you can get with our crappy suspension then your money is better spent elsewhere
Old May 19, 2012 | 12:58 AM
schmellyfart's Avatar
>no body roll
>still on stock springs
jussayin
RSB = Rear Sway Bar
RSTB = Rear Strut Tower Bar
Old May 19, 2012 | 07:38 AM
Yep yep, still on stock suspenstion at 145k on the odo
Old May 19, 2012 | 07:52 AM
TSelanne's Avatar
RSB = Rear Sway Bar
I thought there was only a fstb? Is there one for the rear too? Or is that a typo?
Old May 19, 2012 | 10:14 AM
No typo...there is RSTB but if you don't have an RSB get that first! RSB>rstb every day of the week
Old May 19, 2012 | 10:59 AM
djshwini's Avatar
I understand that any name brand fstb is probably of a higher quality, but i bought mine from ebay for around 30 shipped. Can't beat that...
Old May 19, 2012 | 11:18 AM
Rochester's Avatar
Not a type-o. The RSTB is a minor bolt-on. Search "RSTB", spend a half-hour and read up.
In ROI terms for the 5th Gen Maxima: RSB > FSTB > RSTB
And if I had to weight them to each other, that would be 5 > 2 > 1
Old May 19, 2012 | 01:04 PM
Blue Mesa's Avatar
Is the front strut bar even really worth it then? Im debating between this and subframe collars for my next suspension upgrade...
Old May 19, 2012 | 01:27 PM
Front strut bar before rear strut bar. Rear sway bar first, or @same time as fstb
Old May 19, 2012 | 01:48 PM
Rochester's Avatar
Worth it for what... as a suspension mod? Well, yes, in its own right it's a valid suspension mod. Of course, like many things, the more expensive one that you buy (Stillen) tends to ruin the ROI because they all do the exact same thing. Your $30 FSTB will work just as well, and look acceptably well, too. However, you're asking which would I do between a FSTB and the subframe collars? My answer is get them both, but prioritize the subframe collars. And get the ES subframe bushings while you're at it.
You know, there's a whole different part of the equation which factors into this for some people, and that's engine bling. It's kind of hard to deny the engine bling win of the Racingline FSTB. (They make a fine battery tie-down, too.)
Old May 20, 2012 | 06:44 AM
Prophecy99's Avatar
Agreed, I like how Roch put it, after havin these mods for some years now
FSTB is about a 2.5 out of 10 in feedback
You'll love the the subframe collars as that's the closest thing you can get to a LTB Stage II nowadays..
still wanting to try a RSTB but the cost due to being endangered doesn't jusity the 1.5 out of 10 feeling you would probably get
Old May 20, 2012 | 08:11 AM
Rochester's Avatar
I'd even go so far as changing my RSB > FSTB > RSTB assessment ratio to 10:03:01 respectively.
If I had to change things to factor the subframe collars into it, I'd say RSB > FSTB > Collars > RSTB at 10:04:03:01
This an interesting approach to weighing mods against one another. I wonder what else we could compare? It could be a fun thread for a while.
Hmm... here: http://forums.maxima.org/5th-generat...ml#post8480730
Old May 20, 2012 | 10:26 AM
I'd put the collars before any strut bar.
Old May 20, 2012 | 11:22 AM
ranmas2004's Avatar
I think my RSB made the biggest difference....got a Stillen one. I dont think front strut tower bar matters at all...bought mine from eBAY it works. BUT if you really want to notice a big difference in suspencion, other than getting aftermarket suspension, get ES bushings in all the front suspension parts. makes A HUGE difference in the way the car performs....and ES subframe bushings. and mounts (if you have a manual).
Old May 20, 2012 | 11:51 AM
If you need a RSB.....
JM Autoracing having a Sale on the Progess Ones.....
http://forums.maxima.org/5th-generat...b-95-03-a.html
Old May 20, 2012 | 05:48 PM
TSelanne's Avatar
Yep I'm in on the group buy.
Is there a particular brand that is recommended?
Old May 20, 2012 | 06:03 PM
Damn it, since he is waitng on 2 more guys to call with info to charge...
Old May 20, 2012 | 06:37 PM
CVicVogel's Avatar
Mine is an ebay type bar. It does help the front end in reducing understeer since now, there is less flex. Not a miracle cure... but every little bit helps.
CV
Old May 21, 2012 | 06:25 PM
T_Behr904's Avatar
Old May 21, 2012 | 07:18 PM
Grand_hustle17's Avatar
OP save the $$$ n buy a RSB u will feel better about Ur purchase
Old May 21, 2012 | 07:20 PM
CV
... From what I understand its the rear of the Maxima that giver out... Not so much the front
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
