5th Gen Ranking Thread - Bushings and Collars
Another ranking thread, this time for suspension parts on the 5th Gen that aren't so much "bars" per se, but bushings. You know, rubber and polyurethane inserts.
To get the ball rolling, I'm proposing the following sequence, with a 20:1 scale.
Feel free to rearrange, re-rank, or add on-topic parts to your own list. And they're just opinions, so keep it civil, please.
20 - Engine Torque Mount Bushings
12 - Engine Pass/Tran Mount Bushings
08 - FSB Bushings
08 - Steering Column Bushings
06 - Subframe Collars
03 - Subframe Bushings
02 - LCA Bushings
01 - RCA Bushing
Personally, I've never replaced the RCA bushing, the Pass/Tran mount inserts, nor the Steering Column bushings. But everything else... yup. 12 - Engine Pass/Tran Mount Bushings
08 - FSB Bushings
02 - LCA Bushings
01 - RCA Bushing
Bought it new in Fall 2002. Modded it slowly over the years according to a fluid plans and a pretty strict budget. Then sold it to merovi in February of 2012. There were enough mods spaced out over time to give me a reasonable voice for opinion, but in the end I'm just a daily driver with a hobby and a trusted mechanic.
Now get out from behind that couch and contribute something on-topic.
As you can tell from my ranking, solid poly bushings (Energy Suspension) in the engine torque mounts is top mod. Hands down, the top mod. However, the inexpensive mods should get some praise, too, for their ridiculously high ROI. I'm thinking FSB bushings and the like.
Severe reduction in drivetrain movement one of my first and best noticed mods
Severe improvement in stability eliminates many noise issues
08 - FSB Bushings
Changed just because i was there did not notice an improvment in handling from this
Changed with motormounts. bushings may of had an effect but would have to remove them to find out
02 - LCA Bushings
Large improvement in handling i felt a noticable decrease in front end slop.
08 - FSB Bushings
02 - LCA Bushings
For myself, after replacing the 8 year old, OEM front-sway bar bushings with new ones from Energy Suspension, my steering felt super crisp and tight. I was very happy with the results. A little surprised, too.
I guess it all depends on how worn the originals are... which goes for anything and everything, really.
That's not what I meant... I meant it as in "what have you unleashed by creating another rankings thread" debate...that fstb thread is interesting enough, y'know
And I'm not much for on-topic since I've got a basically stock 4th gen.
Then you'd rank the FSB bushings really low, I'm guessing.
I replaced the FSB bushings with ES busings. At the same time, I installed Moog endlinks. Just to be accurate, I'll mention that I also installed my BC coilovers at the same time. I immediately noticed how much tighter my steering was. It's sensitivity to steering wheel movement is now almost surgical-grade sensitive - and my stocks weren't in bad shape at all.
As to the ranking, I'll reserve for now and edit my post within a week or so, in which time I will be installing my ES torque mount and subframe collar bushings.
I picked up the M/T mounts just because I found them, and don't want the electric appendages anyway.
Your Max is going to feel very, very responsive with this mod. You're also going to get lots of NVH, but that's the trade-off. And if you like that sort of thing, it's a win-win.
I picked up a set of MT mounts at the boneyard. It's a shame the rubber is in great shape but I already have my ES bushings waiting. BTW, my understanding is that the ES busings will fit in the A/T mounts as well, except you lose the electronic funtion (a plus in anyone's book). If you look at ES's online catalog, it even states so.
http://forums.maxima.org/5th-generat...-protoype.html
Don't forget the upper engine/tranny mounts from Knight_YYZ.
Driver side re-design is done, model sent to molder. My order's in, trying them w/electric mounts.
Thx for the thread, great info. I was talking to a guy who's worked as a mechanic before.... I don't know him well so I can't speak on his experience level, but he mentioned he's put urethane bushings on other cars and over time they start to squeak. Have any of you guys had this experience? Or any other negatives associated w these types of upgrades?
Believe it or not I was looking for something like this. Hopefully everyone is in agreement, or at least close to it. With all the different bushings that can be upgraded its nice to know where to start considering they will all need to be replaced eventually. The car is ten years old and I'm sure its time.
Does the Engine Torque Mount Bushings and Engine Pass/Trans Mount Bushings get rid of the excessive slop between load and unload especially with the trans? Or to put it differently, when you are on the gas or off the gas. My girlfriend is really tired of me jerking her head around.
Since I can't be bothered too learn Rochester's ratio system I'll just throw my 2 pennies in on the shifter assembly bushings,
All the other ES suspension bushing parts I replaced had a slight increase in handling responsiveness and feel (Except my RCA bushings which I felt nothing from)
But the ES Shifter assembly bushings were one of the best mods I ever did on my car. Uber cheap, and constant gratification every time I shifted.
Considering how inexpensive they are, and the 100% DIY nature of the installation, the shifter bushings rate really, really high.
How high? I don't know, I can't figure out my rating system either.
When the engine is comes under load, (which is typically at idle when you apply the accelerator hard), the resulting torque lifts the engine. There's a significant amount of energy applied to lifting a very heavy weight. And it does this because it can, what with the engine mounts giving it the play to do so. This is by design, to smooth out the NVH between the engine and the chassis. However, when the engine mount bushings get old and sloppy, there's more lift, more wasted energy, and your GF's head gets knocked around like a soccer ball in a laundry bag. (Nice image)
When you put stiff bushings in the engine mounts (like solid poly), you reduce the amount of lift in the engine. Energy is more readily transferred from the engine, through the transmission and to the drive wheel(s). You get a lot more NVH (Noise, Vibration, Harshness), but you also get a much quicker response from the throttle.
This is why NWP Engineering calls their engine brace a "Torque Link".
So, to sum up:
- Sloppy bushings - GF's head gets knocked about
- OEM bushings - GF falls asleep in your boring sedan
- POLY bushings - GF's seat vibrates
My guess is she might like #3, but I don't know. The god's honest truth is that most people don't care for the NVH that comes with these mods.
I'm no engineer, but here's my understanding... right or wrong.
So, to sum up:
So, to sum up:
I could care less about NVH, mainly because my outer tie rod ends and sway bar end links were just replaced (with MOOG of course) and I'm a happy camper every time I drive the car. Good God nothing could be more noisy than that crap.
I shall ask her about #3. With the addition of vibration she may be interested.
guys have any opinions on this?
http://www.nwpengineering.com/Phenol...tml#TorqueLink
Not really a collar or bushing, but....
Like the solid poly torque mount bushings... a much more responsive throttle off the line, less (to none) lift on the engine, yadah yadah yadah.
It's all good. Plus, it's adjustable, and very easy to remove/re-install.
But if you think the NVH is harsh with poly torque mounts, this thing is brutal for some people. Personally, I liked it, and so does merovi. He keeps it on for daily driving just like I used to.
MAXSE5SPD
Sep 17, 2022 04:00 AM
