Broke a bolt installing subframe collars... Does it matter?
Old Jun 14, 2012 | 12:15 PM
TheIntrepidMontti's Avatar
i snapped one of the 2 bolts that hold the black brace to the car that also attaches to the rear subframe bolt... Whats the implications of this... It wont move due to the other bolt so i think ill be ok but wanted to check.
Old Jul 6, 2012 | 09:15 PM
bueller...
Old Jul 6, 2012 | 09:21 PM
nelledge's Avatar
"I'm just sayin'..."
Replace it.
Old Jul 6, 2012 | 11:07 PM
blue_magicSE's Avatar
Com'onnnnnn
Old Jul 7, 2012 | 07:48 AM
DennisMik's Avatar
With the way all these companies try and make things as cheap as possible, if they put a bolt in, it's because it's needed.
Old Jul 8, 2012 | 08:59 AM
well its gonna be a pain to replace it but i guess ill have to try, half the bolt is still in the car where it snapped so id have to drill that out, re-thread it and put a new bolt i i guess
Old Jul 8, 2012 | 11:58 AM
nelledge's Avatar
Have you tried an EZout, yet? I would go that route before resizing the bolt or heli-coil. Soak it with PB Blaster several times before attempting to remove it.
Old Jul 8, 2012 | 01:10 PM
ShocknAwe's Avatar
dont listen to these kids. Hell you really dont NEED 4 tires but these amateurs need 4 to drive like me
Old Jul 8, 2012 | 02:59 PM
Rods03Max619's Avatar
Originally Posted by nelledge
Replace it.
Agreed or take it to a shop and see how much they will charge to get it out...
Old Jul 8, 2012 | 04:33 PM
No ill take a look at that thanks
Old Jul 9, 2012 | 08:16 AM
djfrestyl's Avatar
Suspension Yoda
DEFINITELY get a replacement in there. I would not drive without a subframe bolt.
Old Jul 10, 2012 | 06:54 AM
Its not the actual subframe bolt, its one of the bolts that supports the bracket attached to the subframe bolt. The brackets got one good bolt in it, but yea i definitely need to try and get that out
Old Jul 10, 2012 | 08:31 AM
ranmas2004's Avatar
TIP
When dealing with trying to remove old rusted bolts. Turn the bolt to loosen just a little then turn bolt back to tight, then turn bolt back to loosen a little more than before then tighten the bolt back...continue this way so that the rust and crap works its way out the threads of the bolt then it will come out instead of trying to get it to come out in one twist...thats how stuff snaps.....my mechanic showed me this trick.
Old Jul 10, 2012 | 08:34 AM
djfrestyl's Avatar
Suspension Yoda
Use the trick all the time.
I also spray the threads as I tighten/loosen the bolt. Helps to seep penetrating fluid into the gunked up threads.
Old Jul 11, 2012 | 07:16 AM
Originally Posted by ranmas2004
TIP
Good looks ranmas ill defiantly be using that from now on
lowpost99
Oct 26, 2025 06:53 PM
MaxLife17
Jun 27, 2019 01:37 PM
captchaos
Mar 15, 2016 12:18 PM
Maxboy23
Sep 4, 2015 06:04 PM
mix master
Sep 4, 2015 05:50 PM
