Steering Wheel Removal
Old Jun 14, 2012 | 03:26 PM
Will's Avatar
Hey guys, I'm planning on removing my steering wheel, but just wanted to check in to see if there are any precautions I should note other than disconnecting the battery terminal for 10 min before unplugging the airbag harness.
Should I lock the steering wheel with the key out before taking off the 19mm nut? Anything I should be aware of or could I just gently wiggle the steering wheel off after the nut and heated steering wheel harness are off?
Thx in advance!
Old Jun 14, 2012 | 03:59 PM
TunerMaxima3000's Avatar
Impact gun and steering wheel puller (t bar with assorted Grade8 bolts)
Without an impact gun it'll be a cak. I wouldn't trust the steering lock to hold against it, you could end up breaking hte steering lock.
Old Jun 24, 2012 | 12:14 PM
Will's Avatar
Thanks Tuner.
I finally got around to installing my Infiniti QX4 woodgrain steering wheel. I had to separate the wheel from its column trim piece to fit on the Maxima's column trim piece. The only thing I noticed is that I lost 1/4 turn on each side for lock, did I do something wrong? The car otherwise steers normally and feels tight like before, and looks more luxurious (and less sporty, hehe).
lowpost99
Oct 26, 2025 06:53 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
coasterswim
Sep 2, 2015 07:43 AM
