G35 coupe 18s rubbing , need help
Old Jun 24, 2012 | 03:38 PM
Sladkixxx's Avatar
So I bought some wheels from g35 couple, 7 spoke 18x8. The front wheels fit whithout any problem because the tires size is 225/45/18 but the back one are rubbing because they are 245/45/18. So the question is what tire size should I buy to get rid of the rubbing issue, my suspension is stock. Will be getting some tokico HPs in the near future cuz my stock ones are leaking but will keep the stock springs.
Old Jun 24, 2012 | 04:22 PM
Huttig2009's Avatar
You need to go with some 235/40/18 tires. I had the same problem with mine when i first got them. But this tire size solved the problem.
Old Jun 24, 2012 | 04:37 PM
VQP0WER's Avatar
Roll the fenders.
Old Jun 24, 2012 | 04:41 PM
Grand_hustle17's Avatar
the rims are not staggered so this is a simple question i think you shouldve been able to figure out on your own lol... use the same tire profile as the fronts... 225/45/18
Old Jun 24, 2012 | 04:51 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Something is wrong with your car or the tires are actually larger than that.
I have the same rims with same tires and it's impossible for them to rub. The clearance is huge. The front is another story when turning...
Old Jun 24, 2012 | 04:55 PM
cjandura's Avatar
dont you have to grind that little tab off on the inner bumper
Old Jun 24, 2012 | 05:03 PM
gatsugansu's Avatar
^agree
Some folks lack common sense.......
Old Jun 27, 2012 | 08:08 PM
Sladkixxx's Avatar
thx
Old Jun 27, 2012 | 08:34 PM
maxed_out_99's Avatar
i went with 225/40/18s and they fit good no rubbing and im pretty low
the rims dont look staggered but the offset is
Old Jun 27, 2012 | 09:41 PM
picnik99's Avatar
OP, do what i did and put the 245's in the front.. it's a quick fix until you have money to buy tires that fit
Old Jun 28, 2012 | 07:14 AM
02whitemaximase's Avatar
I have the same exact tires and rims. I have the rubbing in the rear even after grinding the tabs and rolling the fenders. I switched my eibachs for stock springs only in the rear and the rubbing only occurs on large dips/bumps. If I have people in the back then it rubs all the time. Get 235/40/18 tires, I have read that those will solve the problem, even if you are lowered.
Old Jun 28, 2012 | 07:25 AM
phatboislim's Avatar
no they arent, the G35C wheels, like the ones in my sig are 18x8 +30 all the way around. when i ran 245/40/18s on mine, they rubbed in teh rear, because of that tab on the rear bumper. that's it
Old Jun 28, 2012 | 10:32 AM
I may have been mistaken. The rims on my max the 05 G35 coupe wheels do have a staggered offset I put the rear rims in the front and the front in the read and it looked goofy
Just my .02 cents
Old Jun 28, 2012 | 10:44 AM
because the rear sit in more than the front, its how the maxima is setup. it does that with any wheel
Old Jun 28, 2012 | 10:46 AM
tseng1023's Avatar
When mine rubbed I was told to grind the plastic on the little tab behind the wheel and bend the metal up with a hammer.
Old Jun 28, 2012 | 10:54 AM
just bend the metal, dont grind teh plastic, that's the bumper that's bolted to the tab/metal you bend
Old Jun 28, 2012 | 12:46 PM
Then why are the rims marked front and rear?
And why when I rotated them does it now sit flush?
It doesn't poke in the front anymore.
The offset is staggered google it
Old Jun 28, 2012 | 12:49 PM
front come w/ 225/45 i believe and rear 245/45 on teh G35 the wheels are not staggered
http://forums.nicoclub.com/g35-g37-o...s-t342067.html
Old Jun 28, 2012 | 12:55 PM
your going to make me video this
Old Jun 28, 2012 | 01:02 PM
i've had the wheels and the specs are listed, what more do you want?
Old Jun 28, 2012 | 01:11 PM
100% correct, just look on Irish's infiniti wheel thread. The g35 did come with 225 up front and 245 in the rear and all four rims are +30 offset.
Old Jun 28, 2012 | 01:22 PM
I want you to simply just answere my questions
Old Jun 28, 2012 | 01:24 PM
because the front got the 225/45 and the rear got 245/45...i'm willing to bet that your wheels were marked by someone at a shop. i've had 2 sets either i didnt look that hard or didnt care, but looking at the stamping at the back of the wheels it tells you exactly what the specs are 18x8 +30 offset, period
Old Jun 28, 2012 | 01:34 PM
I just don't get it at all. It's not drawn on my rims with
a crayon or anything it's stamped from the factory.
I replaced all 4 of my tires with a matching set. 225/40/18. If I put the "rear" rims in the front they poke. If theyre where they should be that all sit flush. I don't understand what would cause that if the offset is all the same
Old Jun 28, 2012 | 01:37 PM
facts are facts, and numbers dont lie, if you have the wheels i have in my sig, they are not staggered, period
Old Jun 28, 2012 | 01:39 PM
You really didn't answere my question at all. Period
Old Jun 28, 2012 | 01:40 PM
Chris Gregg's Avatar
Get Off My Lawn
Everyones car is a little different. I've run the 350z rims with 30 offset and 245/45/18 all around. Love the stance it creates and how it my fully fills the fender gap! I've got an Eibach drop and rub on the rear passenger side only if I have a full backseat/trunk or hit a bad dip in the road, but my rubbing is only slight.
I plan on slightly rolling my rear fenders or installing the Q link at some point.
Old Jun 28, 2012 | 01:43 PM
ohhhhhhhhhhhhhhhhh kkkkkkkkkkk. your only concern is front and rear being stamped on your wheels and i told you a possibility and that i never paid attention to taht on my wheels just the numbers. told you the stock tire sizes on the G35. like i said, numbers are numbers and they are not lying. them being front and rear specific is only for the G35 because of the tire size, and technically it doesnt matter whether the front stamped is on the rear and vice versa. the stats on the wheel are the same, only the tires made it 'staggered'
Old Jun 28, 2012 | 01:50 PM
Get Off My Lawn
I wonder if pics of these magical wheels would determine that these are not g35 rims?
Pics would set this to rest. Also pics if the stamp you describe would settle things.
Old Jun 28, 2012 | 01:52 PM
Amerikaner83's Avatar
maybe it LOOKS off with the G wheels on the Max because the Max's rears are 10mm further in than the fronts...?
also, the G35 came with more than one rim style...maybe we're getting them confused?
Old Jun 28, 2012 | 02:03 PM
Get Off My Lawn
My line of thinking entirely. With some images of rims and the stamping, should streamline feedback on how to resolve the rubbing.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Pixel
Sep 15, 2015 05:53 AM
thenewguyy
Sep 12, 2015 11:12 AM
