2001
2001
hi folks its my first time posting some problems with my 01.
First of all the support where the radiator is sitting on is rusting very bad, secondly i have a code 403, i am in brampton Ontario area need a good body shop... and what part to clear that code 403.
hope someone have any suggestions on my problems
thanks
suecer
thanks
suecer
Had the same problem on my 01 SE. You have two options when it comes to the rad support. You can either disconnect all the wiring, hoses, cross member and whatever else to unbolt the old support and just throw on a new one, or have the current one chopped and have a non-rusted piece welded back on. I'd personally prefer to do the unbolting and go thru all that work cause then you wont be relying on the body shop's welding abilities.
thanks for your quick response is that cross member attach to the body of the vehicle left to right and the front engine mount is on that same support i think
Here's a pic of how bad my situation was:
AaronL
Aug 8, 2020 10:31 AM
QueensMAX
Sep 15, 2015 04:14 AM
