Changing ignition coils and spark plugs. Any good vendors?
Old Jun 25, 2012 | 05:53 PM
gavin68's Avatar
Where would you guys recommend getting spark plugs and ignition coils from? I understand that OEM coils are pretty much manditory if I don't want the SES to remain on...
Old Jun 25, 2012 | 06:22 PM
T_Behr904's Avatar
OEM.
Old Jun 25, 2012 | 06:54 PM
Amave's Avatar
i bought some of my coils from Napa, Advance Auto, and Auto Zone and haven't had a problem yet ...
I would suggest getting coils ( all 6 ) from one place so IF they ever go bad you can get them warrantied ( IIRC Advance Auto has lifetime warranty on the coils )
Old Jun 25, 2012 | 07:31 PM
gavin68's Avatar
I'm going to play it safe and order them from Nissan. The part number should be 22448-2Y001 and they have pink dots on them, right? Are they all the same size for all 6?
Old Jun 25, 2012 | 07:55 PM
02pearlmax's Avatar
I'm not sure about the specific part number, but the part number for all 6 should be the same as they can be swapped from cylinder to cylinder with no problem.
For spark plugs go with NGK Iridium's.
Old Jun 25, 2012 | 08:20 PM
DjHackStyle's Avatar
http://rockauto.com/catalog/x,carcod...,parttype,7212
get the spark plugs cheaper here, get the NGK Part # 6240 {#PLFR5A11} Laser Platinum
thats the original plug that comes on the car from factory, cant go wrong.
thats for a VQ35, u didnt mention which engine.
Old Jun 25, 2012 | 09:31 PM
T_Behr904's Avatar
He lists his car in his sig as a 2000, so it's the De-k 3.0, which has different coil packs front and rear.
Old Jun 26, 2012 | 10:13 AM
02pearlmax's Avatar
Ohhh I didn't catch that. My apologies to the OP.
Old Jun 26, 2012 | 05:02 PM
Rods03Max619's Avatar
Prices are about the same as Autozone for Plugs and dont have to wait for it to arrive....
Old Jun 28, 2012 | 03:59 AM
CMax03's Avatar
OEM for me...too many horror stories with AZ/Advance/O'Reilly coilpacks..... My "03" originals were removed from service @ 139K and were working fine...Hope you can get 9 yrs of service out of those aftermarket parts.....
Old Jun 28, 2012 | 08:34 PM
mccpu's Avatar
For 2000, they have grey dots on them and the part numbers are...
Front: 22448-2Y005
Rear: 22448-2Y000
Old Jun 28, 2012 | 08:49 PM
Chris Gregg's Avatar
Get Off My Lawn
Www.Nissanpartsasap.com
Call them.
Old Jun 28, 2012 | 09:00 PM
Shift_A32B's Avatar
OEM Ignition Coils. End of story.
NGK ___________.
Old Jun 28, 2012 | 10:13 PM
gavin68's Avatar
Originally Posted by Chris Gregg
Absolutely, I've been going back and forth with someone from there about the error codes I'm getting. Quite honestly it's very likely to just be a faulty MAF, but I am going to change out at least 1 factory original coil and all the spark plugs.
So, I guess the question now is: OEM spark plugs or aftermarket?
Old Jun 29, 2012 | 12:15 PM
Get Off My Lawn
NGK platinum is what Nissan uses. NGK plat. is what you should be using.
Old Jun 29, 2012 | 12:59 PM
gavin68's Avatar
The order is in for 6 OEM plugs, 1 ignition coil, and an MAFS. Thanks guys for all your help hopefully this will be the end of the SES for a long while.
Old Jun 29, 2012 | 02:32 PM
shaks's Avatar
you should check the TSB, there was a recall on them and if you still have the original ones - you might be able to get them replaced to white dot ones at the dealer
Old Jun 29, 2012 | 09:53 PM
gavin68's Avatar
I'm sorry, what is a TSB?
Old Jun 29, 2012 | 09:57 PM
Get Off My Lawn
Technical service bulletins.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
RealityCheck
Aug 5, 2015 06:18 AM
maxima297
Aug 3, 2015 12:50 PM
