Advise on CPR job
Old Jun 30, 2012 | 05:20 PM
the_oracle181's Avatar
Advise on CPR job
Hi guys, I have a Nissan Maxima 2003 with 140 K on it. I am hearing a rattling sound (mostly from the rear end) when I drive it around 15mpl... It maybe there at higher speed but its not noticeable. I showed this to Meiniki and they said I need to have a CRP (Caliper , rotor, pad) done for the rear brake. According to them the brake is not being released completely after being engaged and hence is rubbing againt the tire which causes this sound.... THey have estimated $700 for the parts and labor
I want to know whether this is a reasonable price or it looks a bit too much. Should i get this done by buying the parts myself and from a local/craigslist mechanic. In this case, where should I buy the parts from. I am new to all this
Thanks for your advise
Old Jun 30, 2012 | 05:32 PM
cjandura's Avatar
$100 for caliper and $30 for pads maby $20 for rotor rockauto.com mad its literaly 5 nuts and 4 bolts 1 line and then bleed the braked takes like 25 minutes
Old Jun 30, 2012 | 05:55 PM
dfj240's Avatar
^This. It's not a major chore mate. Grab a friend, a couple of beers, and order a pizza. You'll probably have it done, or at least close, by the time the pizza gets there.
-Nathan
Old Jun 30, 2012 | 07:11 PM
Thanks Nathan and cjandura
Old Jun 30, 2012 | 07:18 PM
ShocknAwe's Avatar
however bleeding PROPERLY is harder than one would think and if your expecting better braking but you have left air in the lines then your gonna be disappointed
Old Jun 30, 2012 | 09:23 PM
dfj240's Avatar
THIS x134085819590825!!
Old Jul 1, 2012 | 07:08 AM
Shermanh700's Avatar
bring it to me and i'll do all 4 brake for 700 with a free oil change man that a easy fix stop playing around with ur money i do my brake in the dark like nothing learn how to inspect your car weekly try remove any rust from calipers or anywhere under the car by simply sanding and anti rust spray lube and grease bleeding your brake check you brake piston for inner rust u never have problems trust me these car are like baby u can't leave then alone
James92SE
142
Jan 2, 2024 09:23 AM
doctorpullit
Mar 29, 2016 11:08 AM
Noela
Sep 26, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
