LED Footwells
You can also just tape the black wire to a metal surface behind the dash if its easier. (I taped mine to the mounting brackets for the HVAC unit.)
I'll post a picture of my lights later, Im on my phone and can't do attachments
I got the LEDglow 35$ eBay pack and want to connect them to my battery but don't want to go through the door to the engine.. Is there a grommet leading to the engine bay that's under the steering wheel?
Thats gonna be a real stretch I'm not sure if the wiring that comes with the kit is long enough to reach the battery. Why not just use the cigarette lighter or a fuse?
No need to be sarcastic. My ground isn't wired like that anymore anyways its done properly now. Both wires are properly spliced to the positive and negative wires behind the cigarette lighter, and I'm suggesting he does the same.
How do I access the cigarette lighter wires?
But I'm a crusty ol' ***** anyways
Just pop up the shifter trim and you'll see the wires and connector that lead to the power outlet. Tap into those wires.
Go out and take out my shifter trim and take pictures for the approval of the intarnetz? Sorry but I'm a bit lazy for that right now. I guess you'll have to take my word for it.
Only chance for redemption from me is you posting a picture of your handiwork for examination.
You probably already know this OP, but make sure that you tape your wiring up well (mostly when you're connecting the wires to the switch) and don't use sh*tty duct tape like I did haha. Buy some vinyl electrical tape from walmart, i think it was around $5? It sucks when you put your trim and everything back, and then the wires come undone and you have to remove everything.
What color did you go with by the way? and post pics when you're done :O
Originally Posted by 02pearlmax
Always disconnect the battery when doing stuff like this. And yes, red to red, black to black.
Originally Posted by CWolfSE
What if I dOnt?.... And do I have to make the cigarette lighter useless or can I splice into it.
If you dont get the wires right, they just wont work, no harm done. just disconnect and switch the wires around.
just kidding. i got it all to work, funny story actually. i had the key off all the way every time i checked to see if it worked; which made me think it wasnt working. but once i turned the key on i had them up and running in 10 minutes. what did you guys with the LEDs do to stick them under the driver seat, i have carpet all under there and my tape doesnt work
