LED Footwells
Old Aug 14, 2012 | 07:27 PM
  #121
02pearlmax's Avatar
I took an exacto knife and put 2 small holes through the cloth, then ran a zip tie through the holes and wrapped it around the strip to hold it up. A twist tie or something similar will work too. It's not very pretty, but it works and nobody will ever see it unless they are crawling around on your floors.
Old Aug 14, 2012 | 08:15 PM
  #122
CWolfSE's Avatar
Gooooooooooooooood idea.
Old Aug 16, 2012 | 03:59 AM
  #123
TunerMaxima3000's Avatar
I am never coming back into this thread
Old Aug 16, 2012 | 02:28 PM
  #124
Maverick4189's Avatar
I just spent the last 10 min reading the whole thread and LMFAO!!
some real "electrical genius" in here...Do it right or find someone that can...good god
Old Aug 16, 2012 | 03:30 PM
  #125
CWolfSE's Avatar
I already did it "right"... I'll post pictures if anyone wants
Old Aug 17, 2012 | 08:23 AM
  #126
Alias6's Avatar
Hopefully this won't start an argument, but cwolfse ignore them, some people on here attack others that know less than they do. Don't take it personally. I'd love to see pictures.
Old Aug 17, 2012 | 09:08 AM
  #127
rayrobot's Avatar
I just read the whole thread and I'm a bit confused. Does anyone know which fuse they would normally hook up the leds to? I know each fuse receieves power at different times, so im wondering which fuse you guys would use?
I want my footwell Leds to come on whenever im in the car (driving, etc). But they should be turned off when im not present. I don't want to go through the hassle of using a switch because i am fine just tapping into the fuse box.
Old Aug 17, 2012 | 09:32 AM
  #128
Alias6's Avatar
You can use a test light (its called something else, but i can't think of the name right now, you use it to find the voltage of a wire) and turn the car on and test the fuses, and when you find one that works when the car is on, shut it off and see if its off.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
