i made a stupid mistake please help.ATF
Hi.. i attempted to do a automatic transmition fluid change cause i refuse to pay 200$ just to refill and drain "ripoff" i picked up 5 Q of mobil 1 synthic ATF.. the mistake i did i unscrewed the engine oil release plug so all the oil that i did few days ago came out lol
.... i cant seem to locate ATF pan so i can drain and refill it please help my max is fresh out of oil now
it,s auto 2k2 max by the way thnks..
Update..... i did the drain refill and the car is shifting smoother now thanks for all ya who helped.. 4.5Q came out and the same went in ...
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
Wow... if you are confusing your engine oil drain with the transmission fluid drain, i'd say your auto mechanic skills are sub-abyssal. My advice to you is: buy 5qt of new engine oil, put it in the engine (refer to your owner's manual to make sure you put that oil in the right place...
), save a couple hundred bucks from your next paycheck(s) and let a pro do that transmission fluid change for you...
![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
Standing in front of the engine and looking straight at it.. the oil pan is on the left (passenger side) and the transmission pan is on the right(driver side).
The tranny drain plug is a size 19mm (maybe 17mm?) if I remember correctly. It's a lot larger of a bolt than the oil drain plug. Hard to mix them up really.
Honestly if you mixed the two of them up maybe you shouldn't touch the tranny fluid. It's not regular maintenance to flush the tranny fluid and there's a bit more involved, you just don't just drain it and fill it.
Replace engine oil with 4 1/2 quarts of Clean oil, the automatic transmission pan is on the drivers side, can't miss it. If it's a manual trans, I have no clue how that set up is. The drain and refill for an auto trans is 4 qts. good luck.
I have a friend who did the opposite the first time he was changing oil on his new car. He undid the transmission drain plug and had to have his car towed for service. Somewhat confused, did you realize the mistake after seeing the color of fluid coming out that it was the wrong one and didn't add more fluid at that point? That would have been double stupid to add another 5 qts of transmission fluid.
To replace it all, you have to disconnect the coolant line going into the radiator and pump out a quart, then refill a quart while cycling the gears. You do this until the ATF fluid is nice in red. Expect to go through about 10-11 quarts of ATF to get it all.
Let's put this in perspective, shall we?
This method you recommend which, while more complete and thorough, also runs the risk of destroying the tranny if mistakes are made. You want to recommend this process to someone who accidentally drained his motor oil when he was going for his tranny fluid.
Really?
DW
Really?
DW
Really?
DW
http://forums.maxima.org/1066054-post2.html
No, there is probably close to zero risk the way I stated. There's even a "how-to" about this stickied in the forums. Thousands of us have done it without a problem. We can't prevent negligence if the guy doing the work screws something up. So....really! According to you, the owners manual shouldn't tell a person how to change a tire either, because that person may forget to torque down the lug nuts, or not have the jack on stable ground. Who's fault is it if something goes wrong?
![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
Fact is, both methods use twice as much new fluid to get out the old fluid. But with Spock's method there's less risk.
DW
Spock says live long and prosper not "proper". i find it amusing thats all i have to contribute to this.
http://youtu.be/Iu1qa8N2ID0
![goofy](https://maxima.org/forums/images/smilies/goof.gif)
DW
I did state that the method that I described replaced most of the fluid. Do it again next year and almost all of the fluid will be replaced. As an anual-semi/anual maintenence item, it seems quite logical.
04-16-2020 05:15 AM
mkaresh
03-12-2018 06:48 PM
