should a new clutch have shake
Old Jul 14, 2012 | 10:32 PM
MONKEYMANMAX's Avatar
Hello this is my first post.
I have a 03 maxima 6 speed and i just had the clutch preasure plate bearing and flywheel resurfaced. So when i dove car away from shop i noticed when ii release pedal it feels like its skipping and motor shakes mostly in 1st and reverse.. drove back to shop and mechanic said it was because its new and needs to break in oh plus it smells a lil.. is this true does it need to break in? its an oem clutch.
Thanks!!
Old Jul 14, 2012 | 10:52 PM
nelledge's Avatar
"I'm just sayin'..."
No. Break in period? Yes, but not for the problems you're having. Your mechanic did something wrong and is trying to hide it or is just ignorant.
Specifically, how did they resurface the flywheel, and was it first inspected for deflection and rotational movement according to the FSM to see if it was still within operable specs?
Old Jul 14, 2012 | 10:54 PM
T_Behr904's Avatar
Hotspots on a flywheel can cause that. It looks like burn marks on the metal. Even resurfacing won't get rid of them. Those hot spots actually change the structural integrity of the metal on a molecular level, and don't "bite" the clutch as they should, which can cause the clutch to chatter upon engagement in 1st and reverse.
Click this and read... flywheel hot spots and chatter
Old Jul 14, 2012 | 11:19 PM
THANKS!
Thanks guys!!
I did take car back just as they were closing so i have to wait till monday to get anything solved!! I had a feeling tthat was BS about it needing to break in!!
Old Jul 15, 2012 | 07:11 AM
T_Behr904's Avatar
Originally Posted by MONKEYMANMAX
Thanks guys!!
Print out that link I posted and take it with you. Knowledge is power.
Old Jul 17, 2012 | 10:28 PM
BAD PREASSURE PLATE
Turns out that the Preassure plate was bad and they had to replace it. MAN IT JUST PISSES ME OFF THAT WHEN I ASKED THE MECHANIC WHY IT WAS SHAKING,, HE SAID OH ITS JUST BECAUSE ITS NEW! I know thew were just hoping I was just going to say OK and drive off! I will never go to that shop again! And if anybody lives in the San Francisco Bay Area stay away from a shop called NIPPON AUTO SERVICE..
I just wanted to thank you guys again for your knowledge..
Old Jul 17, 2012 | 10:52 PM
carsnwomen91's Avatar
welcome to the faggotry of the automotive repair world... i would say 75% of mechanics out there aren't passionate enough about cars to get some things.
Old Jul 18, 2012 | 07:42 AM
Unklejoe's Avatar
What scares me is that they told you they "resurfaced" the flywheel.
You're technically not supposed to resurface a dual mass flywheel unless you have the right equipment (which that shop probably does not).
I just scuffed mine up with a little air powered grinder with a scotch-brite pad.
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
Bonka
Sep 14, 2015 11:18 PM
