Door Alignment - Fixable?
Old Jul 15, 2012 | 10:08 PM
Rob Reinold's Avatar
Hey Guys,
My driver's side door is aligned lower than it should be. Whenever I close it, the door hits lower than it should, and then snaps up into its correct location. I know this happens a lot with older cars (happened with my last car, a 95 altima). I found an article, outlining a process to fix this involving removing the fender, unbolting the door, re-aligning, and then rebolting. I don't believe I have the skills or tools to do that. Is there a more efficient way of fixing this issue, aimed at people who don't have the resources to remove the fender?
Thanks,
Rob
Old Jul 15, 2012 | 10:37 PM
maximatogo's Avatar
Hinges are worn out. Get new hinges. Replace. Done deal. Cant think of any other way even if you wanted to stuff it with newspapers to macguyver it (wth?)
Old Jul 16, 2012 | 03:42 AM
cjandura's Avatar
Search there is a easy fix
Old Jul 16, 2012 | 05:35 AM
02whitemaximase's Avatar
put one or two washers on the bottom bolt of the door hinge. Search and it really is a 75 cent solution.
Old Jul 17, 2012 | 03:30 PM
heyhi's Avatar
I had the same problem. washers work perfect. It takes 10 min to do.
Old Jul 22, 2012 | 12:01 AM
joemax89's Avatar
I had the same problem so I did the washer thing at it doesnt sag as much anymore but now it still doesnt close right. I have to shut it harder then any of the other doors so is it possible that the latch inside the door is damaged from it being sagging and closing incorrectly all these years?
Old Jul 22, 2012 | 10:19 AM
Sneaky Green's Avatar
http://forums.maxima.org/5th-generat...l?ref=esp-link
http://forums.maxima.org/5th-generat...or-sags-2.html
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
